Brian Fredrik
Junior Member
- Joined
- Oct 4, 2005
- Messages
- 18
- Reaction score
- Location
- Kent, New York
Quick question. Is there a good reason why I cannot begin constructing my 15.5 foot, (4 inch of rocker) plywood skiff with the bottom first. Then install chine logs, frames (3), transom. Then scribe the plywood topsides and cut. My reasoning is that the curve for the topsides is easy to determine. I used this method with a flat bottom kayak I designed and built years ago and it worked great. My worry is that all skiffs I find seem to be built with the topsides first...(no way I'm the smartest in this room). Thank you.
