jlundquist
New Member
- Joined
- Apr 22, 2011
- Messages
- Reaction score
- Location
- florida
Note: This feature may not be available in some browsers.
Here are some stringers systems that some boat manufacturers use for their boats. Just in case anyone would like to switch from wood to Foam filled. They can be used as ideas. But remember, not every boat is the same. They all have diferent configurations and structural needs. You might just need to check how your original stringers were set, foam calculation, etc.
Hi
Like i've said in another thread, i'm new here.
I was looking for any information available or does anyone knows Flare Boats?
I was kind of bored and started to look for a project boat. I found this boat and bought it to make it a real one, just got here from Florida. I took everything out. The hull is in really good shape except for the floor wich had a couple of soft spots. I've cut the floor out, and found some rotten wood because the previous owner didnt seal the holes on the floor when he installed the console (It's a 17' 6" center console). The foam was real wet (took all out to replace with new), the center stringer was rotten and the ones on both sides in some places. I've made the shape of them before replacing with 3/16 ply. Tramsom is hard and theres no structural damage in any other place.
Well, here i go. I would like to know wich construction method will be better for the stringers. I was thinking of making them in fiberglass (epoxy) filled with foam, or should i stick with ply. Here's a sample were i got the do it yourself idea,
http://www.classicmako.com/projects/ayala/ayala11.htm
I've used to make and repair my surfboards in the past so i'm familiar with fiberglass. Also have a friend who imports resins, foam, mat...to this country wich will be backing me up with my project.
I also would like to know about applying gelcoat manually, i want to make the inside look like the outside of the boat (after the floor is completed and installed).
Thanks for the info and help guys.
