My Tricorn cruising dinghy has a deck stepped mast which can be raised and lowered reasonably easily, by two people, when the boat is on its trailer. The operation cannot, however, be performed - at least, not safely or securely - when the boat is afloat, unless alongside a quay with the aid of a crane.
I'm hoping, by fitting a tabernacle, to make it easier to raise or lower the rig both while afloat or onshore. Apart from being able to navigate under bridges, I believe there may be a couple of other advantages, such as spreading the rig load over a greater area of deck, and providing a couple more places for cleats and general halyard tidiness.
This is the sort of thing I have in mind, though probably a little smaller:
The mast is a Proctor alloy mast (F section, I think) dating from 1962. it's in good condition without any dents or repairs.
My question is, does the mast need to be sleeved or reinforced in any way at the point where the pivot bolt will pass through? I'm worried that the bolt hole might become enlarged, and the metal around it cracked or torn.
