First project thoughts and costings ?
Discussion in 'Wooden Boat Building and Restoration' started by flanagaj, Oct 16, 2011.
  1. flanagaj
    flanagaj Junior Member
    Hi All,
    Before I post, I just want to say hello!
    I am looking to build my first boat and have set my eyes on a classic wooden speedboat. Before you say "Just hang on a while that is too advanced", I just want to say that I am furniture maker and have expertise in woodwork/steam bending and am also competent in lamination and epoxy resin fibre glassing techniques. I am hoping that from a construction perspective it will be a challenge but within the realms of my skillset.
    The one aspect that I am totally unsure about is the power plant side and all of the electrics. I am also concerned as to how you go about working out the total build cost for such a project ?
    The link below shows the boat I have in mind.
    http://www.classicwoodenboatplans.com/mucho-gusto/
    Any pointers would be most welcomed
  2. sean-nós
    Likes: 30, Points: 0, Legacy Rep: 392
    sean-nós Senior Member
    Hi flanagaj, The boat looks very like the one that I am building at the moment "crackerbox" you can see my link below, and if I can do it with no real skills it should be no problem to you. I got a great book from Glen-L called "inboard motor installations" that will help you with every step of your engine setup.
    As for cost I guess you can spent as much or as little as you want, I am finishing mine in mahogany "not cheep" but some people just paint the hull or varnish the plywood. For all the running gear and trailer I bought a donor boat and even though the engine had a cracked block I still saved on parts and was happy to buy a new long block for my own piece of mind.:)
  3. flanagaj
    Thanks for the book recommendation. I will take a look at that.
    With regards to "if I can do it with no real skills it should be no problem to you" all I can say is that your boat looks amazing!!
    PS - Are you able to tell me how much it cost you to complete. Would be good to get a rough idea.
    Thanks
  4. sean-nós
    The one with the outboard cost me about €2000 but I used a lot of scrap hard wood that a friend had for fire wood :D for the engine I put a few requests in the free adds looking for old broken outboards and ended up with 6 of them.
    The crackerbox so far for the donor boat the new longblock,chrome dress up kit , mahogany, plywood, fiberglass cloth,resin and other bits and pieces €5000 and I'd say it will cost another 2000 or 3000 to get the look and finish I want.
    I do a lot of shopping on ebay and set my limit low so sometimes it can take a few months to get a good deal but they do come along.
    You can see how I'm getting on with my build here and I'll keep it updated as I go along. http://www.boatdesign.net/forums/wooden-boat-building-restoration/new-boatbuilder-32783.html
  5. Landlubber
    Landlubber Senior Member
    flanagaj,
    Boats look nice, but do a bit of homework before setting solid the design you will build.
    You will have no worries building a boat like that being a fine furniture maker.
    The design is what I an concerned about, what is the average water condition where the boat is to be used, is it for river use or open waters, big difference required there mate, you need a deep V for offshore use or choppy water, the flat deadrise aft is OK for smooth waters but hell in the rough....just have a good honest decision where the boat is to be used before you get disappointed in the results.
  6. flanagaj
    You have raised a very valid point there. The plan is to use the boat on open water, so I suspect that being so flat bottomed it will be terrible in the rough.
    All of the classic looking boats I have seen are flat bottomed ?
    Maybe a rethink is required before making a decision.
  1. Rodrigo Hurtarte
  2. Vesimakara
  3. stewart thompson
  4. jobi64
  5. kwerkus
  6. Barbarosa
  7. djaus
  8. dskira
  9. wsvoboda
  10. DavidC
