Find Centre of buoyancy
Discussion in 'Stability' started by BelgiumLearner, Dec 1, 2011.
  1. BelgiumLearner
    BelgiumLearner Junior Member
    How to find the center of buoyancy on a semi-submerged object?
    Assume a square shaped barge with towers on both sides (PS & SB). Deck already submerged.
    Can someone please give me a hint....
    regards,
  2. jehardiman
    Likes: 506, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Do it by parts, just like a constant density center of mass problem...
  3. BelgiumLearner
    Thank you for your quick reply.
    It does not ring a bell yet.... but i will try to find something about that problem....
    Regards.
  4. BelgiumLearner
    Maybe someone can post a link to material i can read about this subject?
    Google is not my best friend .....
  5. gonzo
    The center of buoyancy is the same as the center of gravity of the submerged section of the body.
  6. BelgiumLearner
    Absolute correct Gonzo, but i'm searching for an semi-submerged object.....
    I responded to quick this morning.... it was stil early...
    The center of buoyancy can be at the same location as the center of gravity.... then there is a indifferent stability. Most of the time you want the center of gravity below the center of buoyancy...
  7. DCockey
    DCockey Senior Member
    Center of buoyancy is the centroid of the submerged volume, whether the vessel is partially or completely submerged.
  8. BelgiumLearner
    Thanks DCockey, but how to find it for a submerged body like described in the starting post
  9. DCockey
    Same as for a floating body.
    Are you using software and the software doesn't seem to work for the particular configuration?
  10. BelgiumLearner
    No... i'm just trying to find out how stability works on semi-sub rigs and/or barges....
  11. DCockey
    Basic principles are the same any floating vessel. Righting arm equals the horizontal offset between Center Of Buoyancy and Center Of Gravity. Static equilibrium is when COB and COG are aligned with one over the other. The equilibrium may or may not be stable depending on what happens at a small inclination angle. If the COB moves horizontally than the COG then the configuration is stable for small perturbations. If it moves less then the configuration is not stable for small perturbations.
    Some of the assumptions used as short-cuts for ships may not be valid for other configurations. For instance the fore-aft stability may not be much greater than the transverse statibility.
  12. DCockey
    Do you know how to find the Center of Buoyancy for a "normal" type of vessel? If so what do you think is different for the configuration you described?
  13. BelgiumLearner
    For a single hull ship, i use Simpsons rule. For a square i use 1/2 * draft.
  14. DCockey
    Use Simpson's Rule the same way as for a ship. Only difference is for submerged portions the top surface of the submerged portion is used rather then the waterplane, but that is the same as for a ship with a submerged bulb on the bow.
    Any more specific questions?
  15. BelgiumLearner
    Thanks David,
    Will continue tomorrow....
