samir elbaguer
Junior Member
- Joined
- Dec 16, 2018
- Posts
- 20
- Reaction score
- Location
- Fort lauderdale florida
Note: This feature may not be available in some browsers.
The new tunnel is made out of fiberglass. They recommend using isophthalic resin to bond it to the hull but I would rather use epoxy if possible.One could always do a full 1-10 taper FG repair then cut a new hole.
But
Depending on the tube material and construction details there may be quicker easier acceptable solutions.
So
What's the tube made of? And picture
Do you know which FG cloths were used in the original construction?
It easier to get to it from the outside. Do you think I can use epoxy? Also, what kind of cloth? The lower half of the hole is about half an inch thick, the rest is about a quarter.Can you get to the backside of it?
I'd probably do a heavy taper of the inner portion, then use some waxed melamine to make an external form, then do a heavy layup tapering in the gap.
That will be an absolute pig of a job to do well.It is incredibly difficult to achieve a quality bond beneath a thruster tube at the best of times.It also will be a unique change in my experience as people never seem to downsize their thruster.I strongly advise seeking out the guidance notes from Sleipner,regarding the blending of the tube into the hull surface.Done correctly,it will reduce both noise and drag.The advice to use isopthalic resin is sound and it will be easier to add a compatible gelcoat and arrive at a good finish.
