marlinspike
Junior Member
- Joined
- Aug 4, 2026
- Messages
- 41
- Reaction score
- 9
- Location
- California
You would need to get inside the mast to actually be able to fix it without breaking the mast which is impossible and then lay a insert.. Those screw holes are minor to the amount of work needed to fix it to an Americas cup version again. How do you laminate the outside without breaking the inital weave.. I think hes right with a tapered stack of carbon and use a glue like spabond or silica with micro fibre and call it a day. If the boat is planning on winning races no one would ever have screwed holes in it. Curse the man that did such a thing
Interestingly long before I owned it, but after the holes were added, this particular boat consistently won so many PHRF races, both offshore and inshore that it caused a huge amount of chaos and headaches for the rating committees- many wanted the rating drastically lowered, and others accused those people of trying to rate skippers instead of boats. The boat is so well known that it’s hard to work on at the dock without a stream of people coming by to talk about its racing history. I very much hope to do a lot of offshore racing in this boat and hope to win, so I want to do the repairs properly. Of course, it’s no Americas cup boat, just an amateur PHRF “plastic classic.”
The holes were added to race with a large asymmetric spinnaker, which turns it into a planing boat in high winds… but the spar engineer does not recommend doing that, so I will be sailing it with no spinnaker. It kind of defeats the purpose of a catboat, which is easy shorthanded sailing to turn it into an overpowered spinnaker boat that now requires a large crew to handle.
