marlinspike
Junior Member
- Joined
- Aug 4, 2026
- Messages
- 10
- Reaction score
- Location
- California
I have a Wyliecat 30 with a flexible unstated carbon mast, and a previous owner drilled holes (I think 3/8") to mount various hardware, which weren't part of the engineering specs for the mast. At this point, it's pretty time tested with those holes in place, as they were installed decades ago, and the boat has been raced and sailed a lot with them, but I'd like to properly fill and repair them anyways. Is it reasonable to just fill with thickened epoxy, or should I perhaps also install a carbon patch over it? Does adding a patch risk creating a hard/less bendy spot in the mast that could be worse than just leaving the hole?
Sorry for asking a maintenance and repair question in a construction/engineering forum, but I feel this is really a technical spar engineering question, given the complex engineering that goes into designing a composite mast like this. I will also try to get ahold of the engineer that designed the spar and ask for their opinion, if possible.
