Fiberglass overlaps , why so large?
Discussion in 'Fiberglass and Composite Boat Building' started by sabahcat, Nov 23, 2011.
  1. sabahcat
    Likes: 28, Points: 0, Legacy Rep: 273
    sabahcat Senior Member
    So on a typical cored panel where the skin is about 1 mm thick?
  2. waikikin
    waikikin Senior Member
    I'm all for scarfing too, with a simple jig it's pretty quick, also what your saying about the timber being a unifiber in the"layup" rings true with some comment I've read from a cluey NA/Designer(cant remember) that strip timber composite/glass can be considered as a solid layup rather than purely a cored sandwich.
  3. PAR
    You have to compare apples to apples. If the core is offering some longitudinal stiffness, such as that with strip plank or panel stiffness as in other cores, the skins can and typically are thinner. In these cases,
    (assuming: [​IMG] or for less dense cores [​IMG]) you need to go with the designer's specs in regard to laps, and joints.
    Well staggered strips with a minimum 'glass sheathing, that's there for little more then abrasion resistance and water proofing can live with butt jointed strips, but again it means well staggered joints and good inter-strip bonding/fastening. In the case of true cores, I treat them all the same (gyrational spacer) and other then good laminate and inter-panel bonds, the monocoque skins bear the loads.
    In light weight cores, the common adhesives are more then sufficient to bond the panels, so a butt joint or lapped scarf will be stronger then the core material. The skins provide the lap, which can be isolated (separate) or part of the panel laminate as a whole.
    This is true of some forms of strip planking, but not all. Strip planking runs the full range from a purely narrow planked carvel build, with a protective sheathing, to a true cored composite sandwich panel. The design scantlings will offer a clue as to the role of the core. I usually make note of the build type in the plans, though I can see where this might not be included in others.
    In the end I'll steal this quote from Trevor Gundberg, an engineer at DIAB (Divinycell manufacture), taken directly from one of their technical bullitens:
    "For joining foam core laminates, again any typical composite adhesive will work in a variety of joint configurations. Probably the most recommended joint is the lap, with the core components butting up together and the skins on either side creating the lap. This creates a continuous skin over the core joint, thereby not creating one weak point in the laminate. Other favorable joining methods would include scarf and stepped joints. Again, the adhesive must be stronger than the foam core, and the skins must be continuous over the core joint."
    1. CapeDory
    2. First class repairs
    3. Abcie
    4. aaronhl
    5. Jason Rodgers
    6. mrG
    7. Jason Rodgers
    8. Space
    9. Tom Peach
    10. DougDA
