fallguy
Boat Builder
- Joined
- Dec 7, 2016
- Messages
- 8,933
- Reaction score
- 2,090
- Location
- usa
Mein Gott. What a thread...I see that a lot are discovering that naval engineering and structural design is not really for uneducated amateurs as that work needs knowledge and experience. It's very funny but I've never seen forums of amateur surgeons or amateur dentists, but there are plenty of guys guessing wildly the thickness of a GRP hull.
First you must have a complete first project relatively precise as the final scantlings will depend of numerous factors specially the choice of the type of reinforcement structure. For example, most of the furniture can become structural reinforcement. For a "slow" summer boat the scantlings can be pretty light as the stresses are finally very moderate. The period of sailing, the kind of navigation thus the elements you have to affront are determinant. You do not build a simple panga for coastal navigation in the Caribbean in light and fine weather like an Alaskan all weather fishing boat.
There is no need of wild guessing, nor divination. There plenty of examples of successful similar designs plus a full big bucket of national and international rules. And some are totally mandatory at least if you want to sell later the chef d'oeuvre, the master opera. Or at least to be capable to get an insurance for it.
The Gerr Book is a good start. It's very conservative -normal in the USA as you do not want to be ruined by some responsibility trial, so you won't be innovative-, truly really very conservative but for small boats in the heavy side it's fairly good and indecently simple tool to use. At the lone condition that you feed the formulas with the good ciphers as close as possible to the reality.
Beginners have a tendency to overbuild as they feel unsure and they have no idea of the real stresses and how to manage it.
So first draw a first project rather complete. Make an estimation of displacement, you can take the displacement of similar boats for a first calculation. Use the fixed furniture as the benches and the floors as structural elements. Decide the type of the structural elements, there several choices and where they are placed.
So, having all the measures, specially the size of the panels between supports, you can use the Gerr book easily with realistic results. No need of a 3/4'" foam, and even less a useless 1/4''. The reality must be somewhere with a 12 mm 90 kg/m3 foam with 3 to 5 mm skins if you use good quality glass, cloth, mat and eventually UD and a good polyester resin like the Reichhold Polylite 480.
A last suggestion. Making laminates is a hard, horribly smelling and itchy work. Do not make your life more miserable with cheap materials of unknown origin from Ebay or some Internet shadow shop.
Use a good resin that wets well like an isophtalic Reichhold. Use good quality glass, mat and cloth, not too heavy.
Use UD if possible, UDs are very easy to wet without air bubbles, and need less mat so you get a better ratio glass/resin.
the only reason I bothered to coin in is noone was pushing back on 11-12mm skins and a 7mm core
I agree the 20mm foam seems a bit much and I agree that this is amateur hour.
But noone else gave him a wild suggestion on skins n core.
I would never design a hull. But I recently got a tender plan and I intend to drop the numbers into Gerr to compare my plan with Gerr. If nothing else; it makes good reading and is a well written text.
