Gianf1041
Junior Member
- Joined
- Sep 4, 2018
- Messages
- 72
- Reaction score
- Location
- italy
In addition to dividing the hull into three zones, within each zone the design pressures are different depending, among other things, on the distance to the stern. Therefore, it is necessary to consider whether, for example, the bow and stern bottom can be the same or not.
And, of course, before calculating the scantlings of each element, it is necessary to define how many transversal or longitudinal elements there are and the separation between them. It is a pity that there are no shortcuts to do things well but this is the design of ships currently, serious, rigorous, technical.
Luckily you are there, I was starting to build "the house from the roof" ........ however I am working in the direction you are suggesting to me.You worry about the thickness but you haven't done your homework yet. As Tansl suggested, you draw the lines first, then calculate the weights/displacement based on what you have drawn. And as Cacciatore has suggested you divide the lines into sections and define the longitudinal spacings. That will give you the grid/panel size.
The thickness of the panels is dependent on the panel dimension, be it a square or rectangular. Then the position of each. Is it at the bottom, sides, or deck? Because each position will have different pressure. There is also the front to back relationship as Tansl has mentioned. Generally, panels forward are thicker as it plows thru the water and there is a reduction of pressure as you go towards the transom. As we progresses, the members here can determine if your boat (depending on speed) will need reduction of panel pressure towards the transom.
Thank you all.
