Fiber glass paint jobs, colors, scheme etc..
Discussion in 'All Things Boats & Boating' started by Vulkyn, Aug 12, 2010.
  1. Vulkyn
    Likes: 46, Points: 28, Legacy Rep: 654
    Vulkyn Senior Member
    Well not sure where to place this question so here goes!
    What kind of colors, paints, stickers etc.. can i place on my boat that will last??
    I would like to know the limitations so to speak. Is it possible to do colors and shapes like the ones done on cars ?
    Can i pimp my boat :D :D ??
  2. hoytedow
    Likes: 399, Points: 93, Legacy Rep: 2489
  3. hoytedow
    Heat and sunlight cause fading. You are amply supplied with both.
  4. Vulkyn
    Indeed .... 45 degrees ..... still i can apply UV protection coat to get some life out of the colors .... i dont mind it fading at some stage ill just try to delay it as much as possible.
  5. hoytedow
    Red fades the worst. Blue fades the least.
  6. Vulkyn
    ok i got some pictures i found online (sorry if its some one's boat or work i am just trying to understand how its done !! )
    I think the last one is computer generated ....
    One company had an extreme edition or something that offered a flame like scheme on the sides, cant find the link though :S
  7. Vulkyn
    More examples :)
    and found it, Four winns frenzy edition, love the scheme !
  8. Vulkyn
    poke ? any one with experience in this area ?
    I'm thinking its vinyl sticker or maybe gel coat ?
  9. hoytedow
    Vinyl stickers shrink and curl at the edges as they weather and go bad sooner than paint.
  10. Vulkyn
    What if i take a varnish, hardener and tenner combo on top of it ? Would that seal it and extend its life?
  11. hoytedow
    I would be the wrong one to ask. I doubt it, though.
  12. apex1
    apex1 Guest
    Always good to see when we have nothing to provide but honesty.
    And you are right Hoyt, it does not last.
    One can put a PU paint job on it, that will fade later than others, but in Egypt the best stains fade out after, say three years.
    On megayachts the paintjob can make for 25% of the overall cost !!!!
    (and has to be redone every 5 - 7 years................................)
    Richard
  13. Vulkyn
    Indeed the weather in Egypt means you are able to use your boat almost 9-10 months (if you deploy in certain area's)
    3 years is acceptable i recon and i did find a supplier who prints using 3M vinyl (and cuts to shape as well)
    Would i be able to get the effect if i added vinyl at the gel coat stage, apply the mold with a color then remove the vinyl to get the effect ? At least that way its gel coat color.
  14. apex1
    apex1 Guest
    Your printed vinyl falls off after one day in sea water (well, may be after one week), and it fades out faster as you can look at it. Any sort of vinyl (PVC) and the like are strictly non permitted on a sea boat under southern sun.
    PU as mentioned....
  15. Vulkyn
    PU? Not sure what that is ....
    I have a friend who does similar sticker / shape / color installation on boats (been doing it for 8 years now) so ill give him a call tomorrow to see how he gets away with it.
    So the frenzy in the above pic is PU ?
  1. Ike
  2. JosephT
  3. D Coleman
  4. dollerprod2
  5. CheoyLee39
  6. man03
  7. Jesse2389
  8. sdowney717
  9. vinay_chari
  10. latunguley
