Hi Vince,
I like your design concepts, you have a good eye. Jets require an uninterupted flow. Deep Vee hulls normally have two jets, one on eithor side of the Vee. Your boat is small and will only have one engine and one jet. You can reduce the Vee as the hull transitions aft and have a small flat section for the jet drive on the centerline. Just be aware that you need a transition for water to happily go into the jet.
It has already been mentioned, but the longitudinal center of buoyancy of the hull needs to coincide witht the longitudinal center of gravity. You have an evolving design concept. Get the size of the engine and fit it into your design along with your general arrangements. Odds are you will tweak your hull a bit before you are happy. After that you nee to make a weight take off to locate the center of gravity. I can send you a sample spreadsheet if you don't have one.
I designed a 28-ft boat with a rounded transom that looks similar to your original concept. In order to keep the boat from being "tippy" I kept the waterline beam constant from midships aft to the transom. Making a small model is a great idea.
I don't think I have offered you any new advise or insight, I hope it is helpful.
Best Regards,
Roger
Best Regards,
Roger
