.fbm to .IGES convertion (DelftShip to Rhino 3D)
Discussion in 'General Computing' started by BTG YACHT DSGN, Jun 20, 2010.
  1. BTG YACHT DSGN
    Likes: 3, Points: 0, Legacy Rep: 38
    BTG YACHT DSGN -sailing is believing-
    I would be very grateful if somebody would be so kind and convert (export) my .fbm file so that I can open it as a precise 3D surface in Rhino (seems to call for an IGES file format).
    I'm goin mad with tracing the hull lines and every time I loft the profiles the hull has some unwanted imperfections (wrinkles...).
    Please do help me. It's a matter not only of the project, but also of my personal health :D
    Kind regards,
    Jakub
  2. Guest625101138
    Attached.
  3. BTG YACHT DSGN
    Rick, thank you very very much :) That's exactly what I was expecting to have.
    Regards,
    Kuba
  4. BTG YACHT DSGN
    Hi ,
    New project, but still old issue.... I would be very grateful if you could once again help me and convert this .fbm to .iges so that rhino has accurate model.
    I'm sick of fairing curves and rebuilding and I can't make it... :rolleyes:
    Regards,
    Kuba
  5. micspoko
    Likes: 6, Points: 28, Legacy Rep: 96
    micspoko Senior Member
    this is file in rhino
  6. BTG YACHT DSGN
    Thank you micspoko for your help. I do appreciate your feedback :) However I reckon that you exported some mesh file out of DELFTship ( either .obj or .stl, rather .stl because of triangulation ). That's not quite what I was expecting for.
    I tried this method some time ago, but it hardly satisfy me. IGES file is a NURBS surface perfectly working in Rhino. I can make exact deck edges (sheerline connection in particular) and I am not restricted in rendering mesh resolution.
    What is more working on IGES surface allows me to transform it with multiple tools (trims, offsets ( solid shell ) etc. ).
    If someone has pro version of DELFTship, then one can convert easily my file to IGES ( for a beer for him :cool: )
  7. daiquiri
  8. BTG YACHT DSGN
    Indeed, exporting IGES file from FREEship is working well, however I have to remember to model the surface in the FREEship, not in DELFTship.
    The reason for that is FREEship does not recognise the .part files of DELFTship. By now I'm reconstructing the whole model point by point (control point) from DELFT to FREE. Then the export is not a problem at all :)
    Thank you, daiquiri for reminding me of possibility to export IGES files using FREEship instead of DELFTship, where this feature is unavailable in statndard version :D
    Regards,
    Kuba
  9. Adler
    Likes: 15, Points: 18, Legacy Rep: 139
    Adler Senior Member
    what you need....
    Is attached.
  10. johnswe
    johnswe New Member
    Delft->Rhino
    Could someone please help me with the same problem? I would be very thankful.
    Best regards
    John Swe
  11. Adler
    Adler Senior Member
    Your file is converted.
  12. lofa
    lofa New Member
    fbm to iges
    I really need this fbm file converted so could someone please convert this to iges. Thanks to anyone who can.
  13. Adler
    Adler Senior Member
    Converted
    Converted Surfaces 10.
  14. PI Design
    Likes: 21, Points: 0, Legacy Rep: 328
    PI Design Senior Member
    Hello,
    I wonder if anyone would be so kind as to convert this file, please?
    Many thanks.
    Note to self: use freeship rather than delftship in the future!
  15. Adler
    Adler Senior Member
    Converted to .iges
    See please the attached.
