Favorite Type of Power for a Powerboat
Discussion in 'Propulsion' started by mackid068, Jun 27, 2005.
What's your favorite form of propulsion for a powerboat?
  1. Gasoline Outboard (2 or 4 stroke)
    6 vote(s)
    8.8%
  2. Gasoline Inboard
    9 vote(s)
    13.2%
  3. Gasoline Sterndrive (also called I/O or an Inboard/Outboard)
    5 vote(s)
    7.4%
  4. Gas Water Jet (also called Gas Jet or Jet drive)
    1 vote(s)
    1.5%
  5. Diesel Inboard
    20 vote(s)
    29.4%
  6. Diesel Sterndrive
    8 vote(s)
    11.8%
  7. Diesel Jet Drive (see option 4 but replace gas with diesel)
    3 vote(s)
    4.4%
  8. Hydrogen Fuel Cell
    2 vote(s)
    2.9%
  9. Diesel-Electric
    5 vote(s)
    7.4%
  10. Solar Powered
    1 vote(s)
    1.5%
  11. Steam Power
    6 vote(s)
    8.8%
  12. Solar with hydrocarbon auxiliary
    2 vote(s)
    2.9%
  1. mackid068
    mackid068 Semi-Newbie Posts Often
    What's your favorite type of propulsion for a powerboat for your purposes? Outboard, diesel inboard, gas inboard, gas I/O etc.? Please post a reply after answering the survey question to clarify why you voted for the propulsion method you consider the best for your purposes. If your choice was not listed, then post a reply detailing it anyway. I'm sorry if I excluded your choice. Excluded choices include diesel outboards (which do exist!), electric motors and electric trolling motors along with outboard with kicker and dual outboard and dual (insert type)
  2. marshmat
    marshmat Senior Member
    How does one pick from among so many choices?.....
    OK, so I voted for the fuel cells. Not the silly membrane ones from car companies, the real solid-oxide and phosphoric units that can run 24/7. Big problem is fuel storage. Great for a nice displacement-hull cruiser or trawler.
    For the other side of my boating tastes, the runabout side, I'm saying jetpump and biodiesel, just because nothing more hi-tech has high enough power density. And I don't like digging my prop out of sandbars.
    As much as I love solar, and love working on the solarcars, it simply isn't practical for motive transportation except in certain circumstances. Of course, solar with a biodiesel supplementary would be pretty useful for most cruising. How about a nice big Australian cat with U of T's new nanosphere solar stuff....
  3. woodboat
    woodboat Senior Member
    Inboards have proven to be the most reliable. Would love diesel but given the short boating season in Maryland and the fact that I have never cruised more than 50 miles from home diesel doesn't make sense. When I start cruising the ICW to Florida :) I will switch to diesel
  4. mackid068
    Diesel inboards for me. As woodboat says, they are the most reliable, but with diesel, there's no risk of fire or explosion and the diesel inboards are much more efficient than gasoline.
  5. yipster
    Likes: 98, Points: 58, Legacy Rep: 1148
    yipster designer
    i voted hydrogen (fuel cell) instead of steam. although the fuel cell is develloped out and ingenious i belive it must be possible for a boat -better than a car- without a cooled H fuel tank at all to make its own H from the water and burn it directly somehow* in a compressor and use the hot exhoust steam to generate more H. i figger it may be even gas price competative these days...
    *hybrid under hypothetical devellopment ;-)
  6. mackid068
    But what I'm asking is what YOU use, I sort of misworded the question. I'm just wondering what YOU consider the best power for YOUR purposes. Capitalizing YOU just for the heck of it.
  7. yipster
    yipster designer
    hmm, beeing here at BOATDESIGN.NET i thought i trow in my thoughts bout the future ;)
    but ok, my boat (mercs with bravo's) uses gas at E 1.39 a liter :(
  8. Corpus Skipper
    Likes: 8, Points: 0, Legacy Rep: 173
    Corpus Skipper Hopeless Boataholic
    Diesel stern drive for the ultimate in fuel efficiency. With ever increasing fuel prices, mileage (cost of operation) is my biggest concern. Though if the boat is going to be wet slipped in salt water, go inboard for corrosion resistance. (come on Volvo, where's that composite stern drive? :D )
  9. mackid068
    Stern drives are pretty good these days. Corrosion is not AS big of a worry, though it looks like it will be a worry for the near future.
  10. stevel
    stevel Lost at sea
    I love my deisel inboard. For a boat that stays in salt water, it doesn't need all that much maintenance. It takes a bit of skill to dock, but not so much that it should take anyone long to learn.
  11. artemis
    Likes: 15, Points: 0, Legacy Rep: 267
    artemis Steamboater
    Steam is my choice. I've been using it for over thirty years. I like the relative quiet (although the newer outboards are as quiet). The low rpm with a well balanced engine creates a pleasant ride. I'm out on the water to relax and escape today's hectic world. While I may want to go from point A to point B, getting there is more than half the fun. And it's really pleasant to dip into some backwater slough at about 1-1/2 knots and move among ducks, geese, heron, etc. and have them only raise a head to look at this "funny craft" and then continue about their business.
    That said, I'm in the process of designing/building a 22' LOA x 5'8" Beam, tunnel stern Sea Bright Skiff of about 1000 lbs. displacement that will be powered by an engine that goes from 25 rpm to 2000 rpm and from a crawl to 18 mph. Good, modern automatic controls and capable of burning any liquid fuel including waste vegetable oil (coming down the dock one is struck by the smell of McDonalds :D ). It's getting there and in a year or so will be underway.
  12. RANCHI OTTO
    Likes: 37, Points: 0, Legacy Rep: 535
    RANCHI OTTO Naval Architect
    I've voted for diesel inboard but...
    in fact each propulsion system meets to his own boat characteristics..
    RANCHI Otto
  13. mackid068
    Yes, each to his/her own.
  14. RANCHI OTTO
    My apologies...
    RANCHI Otto
  15. mackid068
    No reason to apologize for anything.
