I just finished sanding the whole box again and wiped down. Instead of tape in the corners and I fitted a triangular tape to secure all 3 corners at once.
So the top lip that hangs over the bow of the boat I plan on drilling 3 holes into the boat and using lag bolts from underneath so there are no visible holes.The inside tabs that form a triangle is where I will drill holes on each side and carriage bolt to the boat.Then I was going to 5200 around the perimeter as a caulk and maybe some between the box and the boat.
