Favorie stupid
Discussion in 'All Things Boats & Boating' started by gonzo, Oct 18, 2009.
  1. daiquiri
    Nobody is to blame. The pump has to be matched to a correct motor, or to a correct gear box.
    This drawing will hopefully explain my point better, both engines are rated the same max power output, but have a max torque at different RPMs:
    Cheers
  2. Yobarnacle
    Maybe someone can explain this to me. My knowlege of electrical theory is marginal. The 30 hp motor electric is rated as hi-torque motor. 208v-211v 3 phase. We run at 220 volt. Is the 208volt design, being run at 220volts, what gives it its "hi-torque" as opposed to a normal 220 volt 3 ph motor?
  3. daiquiri
    No, it is about it's constructive characteristics. See the document attached below, pages 3 to 6, where main constructive differences of AC motors are explained. I have downloaded it time ago from somewhere, so don't have a direct link anymore.
    Cheers
  4. Yobarnacle
    Thanks for the great graph. I'm saving it. My only point is, we can't compare apples to oranges. For boat propulsion, a propeller working in water and an impeller in a pump, are doing similar kinds of work.
    The direct drive electric motor is more suited, because of high torque start up, to this task than piston engines with their clutches and reduction gears.
    How much electric motor do you need? A lot less than a piston engine doing same job.
    Different job, like a truck or car? Maybe piston engine more appropriate.
    Trains and ships use diesel electric for a reason. Efficiency.
    Some ships use piston engines hooked to shafts thru gears. Lower initial costs.
    It depends on your application and needs.
  5. Yobarnacle
    Im saving pdf too. thanks. how did you post a pdf? I've tried and won't let me
  6. Yobarnacle
    seems I hi-jacked this thread. Sorry
    I guess its on topic if I make a stupid A__ of myself?
  7. daiquiri
    I have updated the graph, to show the engines of the same max power (plus a correct pump torque curve), as is the point I wanted to explain. Cheers!
  8. Yobarnacle
    Thanks.
    Since I already hi-jacked the thread, let me ask one more question.
    If a vessel design called for a 16 inch diam 14 pitch prop driven by 35 hp diesel with 2.5:1 reduction. but you wanted to drive same prop with direct drive electric. How big an electric motor is needed to swing the same prop? 35hp?
  9. daiquiri
    How about starting a thread dedicated to that question? ;)
    Then perhaps Jeff (BD.net admin) could move there this side-drift discussion about pumps and electric motors...
  10. Yobarnacle
    ok, ok is too few letters, so ok again
  11. hoytedow
    Maybe use the alternative spelling "okay" or "au quai".
  12. Yobarnacle
  13. Yobarnacle
    hmmm? What's MY "favorite stupid" around boat stuff? hmmmm.
    MOI
  14. hoytedow
    My wife's favorite stupid around boat stuff is me. :p
  15. rwatson
    rwatson Senior Member
