ezelfin
Discussion in 'Sailboats' started by 3333feet, Oct 29, 2010.
  1. 3333feet
    3333feet Junior Member
    please analiyze the hull for me
    Design hydrostatics report.
    Designer
    Created by
    Comment
    Filename Ezelfin.fbm
    Design length 13.721 (m) Midship location 6.861 (m)
    Length over all 13.522 (m) Relative water density 1.025
    Design beam 4.257 (m) Mean shell thickness 0.0000 (m)
    Maximum beam 4.282 (m) Appendage coefficient 1.0000
    Design draft 0.554 (m)
    Volume properties Waterplane properties
    Moulded volume 8.787 (m^3) Length on waterline 12.472 (m)
    Total displaced volume 8.787 (m^3) Beam on waterline 3.282 (m)
    Displacement 9.007 (tonnes) Entrance angle 8.732 (Degr.)
    Block coefficient 0.2713 Waterplane area 28.232 (m^2)
    Prismatic coefficient 0.5148 Waterplane coefficient 0.4833
    Vert. prismatic coefficient 0.5613 Waterplane center of floatation 6.160 (m)
    Wetted surface area 31.052 (m^2) Transverse moment of inertia 18.071 (m^4)
    Longitudinal center of buoyancy 6.544 (m) Longitudinal moment of inertia 227.84 (m^4)
    Longitudinal center of buoyancy -2.538 %
    Vertical center of buoyancy 0.361 (m)
    Midship properties Initial stability
    Midship section area 1.244 (m^2) Transverse metacentric height 2.417 (m)
    Midship coefficient 0.5270 Longitudinal metacentric height 26.290 (m)
    Lateral plane
    Lateral area 5.129 (m^2)
    Longitudinal center of effort 7.231 (m)
    Vertical center of effort 0.322 (m)
    The following layer properties are calculated for both sides of the ship Layer Area Thickness Weight VCG LCG TCG
    (m^2) (tonnes) (m) (m) (m)
    Layer 0 85.632 0.000 0.000 0.997 6.652 0.000 (CL)
    Sectional areas
    Location Area Location Area Location Area Location Area Location Area
    (m) (m^2) (m) (m^2) (m) (m^2) (m) (m^2) (m) (m^2)
    0.686 0.000 3.430 0.801 6.175 1.248 8.919 0.946 11.663 0.179
    1.372 0.133 4.116 0.976 6.861 1.244 9.605 0.770 12.349 0.055
    2.058 0.356 4.802 1.111 7.547 1.190 10.291 0.570 13.035 0.002
    2.744 0.588 5.489 1.203 8.233 1.089 10.977 0.362
  2. 3333feet
    sorry
  3. 3333feet
  4. daiquiri
    Likes: 254, Points: 93, Legacy Rep: 3380
    :confused:
