Exposed or Enclosed Propeller Shaft?
Discussion in 'Hydrodynamics and Aerodynamics' started by AlreadyWet, May 7, 2014.
  1. AlreadyWet
    AlreadyWet Junior Member
    This makes sense and is how I pictured it.
    Many of these boats have recently started running a tapered safety collar in front of the bearing housing which, at least in static form, negates the blunt end of the strut tube.
    Thank you again for your reply!
  2. baeckmo
    Likes: 222, Points: 63, Legacy Rep: 1165
    baeckmo Hydrodynamics
    Having a rotating collar is a bad idea, since the power loss ("pumping effect")increases by diameter^5. Better fix it statically to the bearing housing as a nose cone.
  3. gonzo
    That is correct.
  4. bpw
    Likes: 4, Points: 18, Legacy Rep: 34
    bpw Senior Member
    What is your experience with hi speed craft? Just curious where your info is coming from.
  5. Rastapop
    Likes: 5, Points: 18, Legacy Rep: 46
    Rastapop Naval Architect
    The enclosure will widen the profile and add form drag, and the increased wetted surface area will add viscous drag (which at high speed will be a large percentage of total drag).
