Expanding marine foam for composite centers?
Discussion in 'Materials' started by John Smithson, Aug 22, 2021.
  1. John Smithson
    Likes: 3, Points: 3
    John Smithson Junior Member
    Anyone tried using expanding marine foam as a composite center? Instead of the much more expensive sheets or wood?
    Seems like it could be a much cheaper alternative.
    Either pouring the foam into a mold to get the pieces and then glassing those. Or for something larger, putting down the layer of glass and foaming on top, then sanding it down to the thickness / smoothness you are after and glassing on top.
  2. kapnD
    Likes: 567, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    Boston Whaler does that, several others.
    I blew surfboard blanks way back when, we used very heavy two part concrete molds. I have no idea how much they weighed, but a little too much foam would easily lift the top!
    Don’t underestimate foams expansive properties!
    dustman and fallguy like this.
  3. Mr Efficiency
    You can of course buy the pre-expanded polyurethane foam in cut sheets of various thicknesses. The typical 2lbs/cu ft variety is quite friable, and not to considered as structural. 4lbs/cu ft does have much better physical properties, and in less critical applications makes a reasonable core.
  4. fallguy
    Likes: 1,999, Points: 123, Legacy Rep: 10
    The problem is controlling the expansion.
    Boston Whaler and Ranger and probably Tuffy and a few others build this way..but it is a highly engineered process and costly to mould.
    From what I am told, even corecell is made with an expansion reaction in a mould, but have not seen it done.
  5. Mr Efficiency
    Expanding the foam into a core isn't practicable or cheaper
    fallguy likes this.
