Exhaust gas pipe size
Discussion in 'Diesel Engines' started by naserrishehri, Jan 31, 2023.
  1. naserrishehri
    naserrishehri Senior Member
    Hello friends
    How can i select exhaust gas pipe size(dia. And thickness) according to my diesel engine power?
  2. bajansailor
    Likes: 1,783, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
    What size / type of diesel engine are you using?
    Do you have a specification sheet for this particular engine?
    If there is a drawing on the specification sheet (there usually is), you might be able to 'roughly' scale from the drawing re the size of the exhaust?
    Are you referring to the flexible hose connecting the exhaust to the pipe, or the pipe itself?
    If the pipe, will it be made from eg fibreglass or steel, or aluminium?
    If you have a particular engine in mind, then your local engine dealer should be able to provide you with the information required re exhaust diameter?
    naserrishehri likes this.
  3. naserrishehri
    Unfortunately the owner provided a second hand engine without specification or maker drawing.but i know it's power (1200hp) .i m trying to find the engines specification in internet.
    Thanks for your help.
  4. bajansailor
    OK, do you know what the make / Builder of the engine is?
    Is it in vee formation with twin exhausts, or just a single exhaust with inline cylinders?
  5. naserrishehri
    Engine information:
    Mitsubishi
    Ps 1000
    Rpm 1500
    48.3 litr
    12MD
    20MTK
  6. rxcomposite
    Likes: 631, Points: 113, Legacy Rep: 1110
    rxcomposite Senior Member
    The easoest thing to do is to measure the inside diameter of the collector pipe. I assume this is the single exhaust tube that exits out of the hull. Thickness will depend on the dia of the tube. This time, since it is a tube, it is measured from the outside. Pipes are measured from the inside.
  7. Adler
    Likes: 17, Points: 18, Legacy Rep: 139
    Adler Senior Member
    Please,
    Find at first the turbo type of the engine. It is crusial to build the Exhaust Gases formation regarding the back pressure level.
