Evinrude Etec with oil inside case.
Discussion in 'Outboards' started by DogCavalry, Nov 16, 2022.
  1. DogCavalry
    Likes: 1,731, Points: 113
    DogCavalry Senior Member
    Tipped up the engine, made a puddle in the splashwell.
    You can see the high "water" mark on the air cleaner. @baeckmo suggested a reason. I'm gathering data. Engine ran poorly for a week. Now it won't start. IMG_20221116_125926230_HDR.jpg
  2. fallguy
    Likes: 1,893, Points: 123, Legacy Rep: 10
    Open the air box and check to see if it is draining. There is a drain in the bottom. It could be clogged?
  3. DogCavalry
    Will do. Any reader ever opened one of these? The service manual mentions the air box twice. In the intro it describes it. The index says on pg 217 - removal.
    On pg 217 it says, "remove it".
    I've got all the bolts out. It's trapped by something else, but even flopping around loose, engine still won't start. I've hit the starter about 50 times, but no smell of fuel. No oil in water...
    Per @baeckmo I'll try the plugs next.
  4. fallguy
    get an in line plug tester and make sure you have fire; it is a basic test that separates debug between electrical and fuel and after that you'll stop hitting the starter until you find the issue
    But. It sounds like fouled or not getting fuel.
  5. DogCavalry
    Not getting fuel. Fuel pump after that white fuel filter is running bone dry. Poop.
    fallguy likes this.
    At least you know the issue; that is generally good news and easier than a deep mystery.
  7. DogCavalry
    Make further trouble shooting a lot more straightforward.
  8. DogCavalry
    I haven't started cutting off clamps, but the lift pumps in the fuel system run off pressure/vacuum pulses from the cylinder/crankcase assembly. As @baeckmo pointed out, that area has accumulated oil. I might have XD100 all through that system. That would explain everything.
