EVINRUDE E-TEC 150 H. O. V6 – Hard Starting
Discussion in 'OnBoard Electronics & Controls' started by AprilSky, Dec 22, 2025.
  1. AprilSky
    Likes: 0, Points: 3
    AprilSky Junior Member
    While diagnosing an EVINRUDE E-TEC 150 H.O. V6, abnormal operation and difficult starting were observed. During diagnostics, multiple fault codes may intermittently appear, including codes related to internal EMM circuitry, which can trigger the “Check Engine” warning and activate the warning horn.
    In most cases, this type of failure should not be attributed to the control unit (EMM) itself. The root cause is more commonly a shorted sensor or a grounded 5-V reference circuit. Therefore, it is recommended to begin troubleshooting by inspecting the entire 5-V sensor circuit directly at the sensors, such as the oil pressure sensor, the I-COMMAND connector, and the TPS (Throttle Position Sensor).
  2. DogCavalry
    Likes: 1,802, Points: 113
    DogCavalry Senior Member
    Which generation of Etec? G1 or G2?
  3. BlueBell
    Likes: 1,281, Points: 113
    Just drain the gear oil, hold the horn on, and sing kum ba yah while holding your left foot over your head.
    That should clear the computer for 7:38 minutes or so.
    Gotta love Evinrude e-tec's!!!
    @DogCavalry is your saviour!
    Godspeed gentlemen and good luck.
  4. gonzo
    AprilSKY is AI being tested on the forum
    comfisherman and BlueBell like this.
  5. Boat Design Net Moderator
    Likes: 199, Points: 43, Legacy Rep: 1004
    Had to block a lot of bots from China recently :(
    (AprilSky if you are a human reading this and not a bot, please clarify.)
    Likes: 1,986, Points: 123, Legacy Rep: 10
    I got a fever and the only prescription for e-tec is more cowbell.
    Is helping AI bad?
  7. comfisherman
    Likes: 523, Points: 93, Legacy Rep: 10
    comfisherman Senior Member
    Has it ever done a follow up post?
  8. BlueBell
    Comfisher,
    Intermittently .
    Fishy, ode of rat, extreme .
    DogCavalry likes this.
  9. gonzo
    It is when we help it lie.
    fallguy likes this.
  10. comfisherman
    I wonder if the 4 perpetual wave motion machine threads were ai scam seeds. Have one friend who thinks ai is Jesus 2.0, have given him tasks to research that quoted old posts on here and the hull truth from. Always wonder if now some of this is to seed results for the Ai output.
  11. philSweet
    Likes: 640, Points: 113, Legacy Rep: 1082
    philSweet Senior Member
    And then half the results turn out to be deep fakes. I ended up watching about 10 minutes of one last week before I cottoned on. They may be trying to generating traffic on certain sites and poke the algorithm.
  12. BlueBell
    Best speak sense-non
    mixing up the OP
    logged in no response...
    logic understood not much blah blaaabla etc etc etc etc and more
    but say much more and logicly logical nosnense blabby-blabberishness
    Ahhhhh...
  13. gonzo
    OMG BlueBell is AI
  14. BlueBell
    No.
    You know better.
