DogCavalry
Senior Member
- Joined
- Sep 22, 2019
- Messages
- 3,674
- Reaction score
- 1,844
- Location
- Vancouver bc
My 250 etec ho, after lending it out, is apparently overheating.
Good stream at the indicator.
Pump and impellor only have about 5 hours.
On starting, temp on digital thermostat climbs to dangerous levels but alarm does not sound.
If I go WOT for 15 seconds, when I power down to cruise it will be fine until I stop. Until I reduce power it will indicate surprisingly cool. 132°f 65°c.
The first time I drove it after getting it back, I noticed nothing out of the ordinary until I glanced at the digital tach while it was displaying temp. 212°f 100°c! But no alarm. And no steam visible. Good stream at the indicator though. That was at slow cruise: 6 knots, 1100 rpm. Bottom not immaculate but better than other occasions when that speed/power did not cause trouble.
Possible issues:
-something loose inside the engine causing trouble sometimes, then not.
-baked pump from misuse by neighbours. Pump leaking badly and priming poorly w/o the blast of water.
-Faulty thermostat sending nonsensense signals. Although computer should have triggered the alarm at boiling point. And temp resting at boiling point seems unlikely coincidence
-Baked computer from baked pump no longer responding correctly to inputs. Although that also seems unlikely. Because then it probably wouldn't start at all.
-Something I didn't think of
Possible issues:
