Wow, total logic snap there.
"the calculations may be showing that the rotor rig is producing as much power as the author's calculations say," - so what is the problem?
If I change the Rotor configuration, I can "dial in" ANY performance level I want , including Tornado performance.
Even if they got the sail performance wrong, it makes no difference, unless you are in a race.
It doesn't MATTER how well the estimate the original sailing performance. As I showed, IF they had wanted to match a sail rig, they only have to tweak a few Rotor dimensions, and get parity with sail configurations.
"the rotor rig is not half as powerful as the normal Tiger rig as they claim."
That's NOT what they said.
They said the "
lift co-efficient" was equivalent to HALF that of the Hobie, NOT the overall boat performance.
If I loaded a Hobie with a sail with battery, electric motors, actuators ands control gear, THEN you could make a useful comparison.
How much time have you spent sailing a Tiger? How much time have you spent sailing a comparable craft? How much idea do you have about how a loaded-down Tiger compares to the craft in the polars you showed?
You refer to a Tiger being loaded with "battery, electric motors, actuators and control gear". If that added up to the 160-170 kg of a typical Tiger crew then it merely shows how heavy the gear required for a rotor is. However, the photos show that the gear added up to a lot less than a typical Tiger crew. The rotor boat was therefore almost certainly dramatically lighter than a typical Tiger (which it clearly was according to the photographs) and therefore the extra displacement is irrelevant - the rotor Tiger appears to be dramatically lighter than the comparison vessel and in 10 knots of wind that can make a significant difference.
The paragraph comparing the rotor to the standard Tiger rig is as follows;
"The initial rig of the Hobie cat Tiger catamaran (a 17 m² mainsail and a 4.15 m² jib) was replaced by a Flettner rotor in the second prototype. The rotor height is approximately 2.8 m and the diameter is 0.45 m. Taking into account the high lift coefficient of Flettner rotors, it is approximately equivalent to half of the surface of the original sail."
The subject of the paragraph is the rig. The final sentence states that taking into account the lift coefficient, "it" (meaning the rig which is the subject of the paragraph) is approximately equivalent to half the surface of the original sail. The paper does NOT say that the lift coefficient is half that of the original rig, it says that once the lift coefficient is considered, the rotor RIG is equivalent to half the surface of the original rig.
If the subject of the sentence you quoted (
"Taking into account the high lift coefficient of Flettner rotors, it is approximately equivalent to half of the surface of the original sail.") was merely the lift coefficient then the sentence is illogical; there is no reason to include the passage "taking into account" or "it" or "the surface". The sentence would merely read "the high lift cofficient of the Flettner rotors is approximately equivalent to half the original sail". It is against all normal logic to claim that an author included highly significant passages that were totally irrelevant to what you allege they were trying to say.
Even if something has suffered in translation, here we have a 2.8m high rig with a far higher weight than an Optimist rig of similar height AND a motor, that is driving a fast cat platform about a fast as an Opti is driven, and dramatically slower than a Laser 4.7 goes. That is not evidence of an efficient device in many ways.
If they got the sail performance wrong it DOES change things. It shows that the basic calculations of rotor rigs may be incorrect. It may show that other rigs could be more effective in driving merchant vessels. If a rotor rig is significantly less powerful for its area then maybe merchant vessels should be using other rigs for auxiliary power. Why not keep an open mind and use the normal scientific methods of assessing these devices?
I don't know why you are so invested that you misquote people on this forum, as you did to me earlier, and make childish insults. A while back you were making disparaging remarks about those trying to demonstrate rotor rigs, if I recall correctly, and saying that you were going to make one to demonstrate them. I haven't seen the results of your demonstration. I am totally open minded about rotor rigs but that doesn't mean accepting the claims made by those who sell or buy them, just as I don't accept the claims of Ford or their fleet customers about why their cars are better, and I don't accept the claims of Beneteau or the charter companies who buy them about their craft.
Just as with other "alternative" rigs the point is simple - back up the claims in a normal scientific way with normal tests against a reference craft at the same time in the same conditions. This is not very difficult, and should be the norm for anyone wanting to have their claims accepted.
