Everything Old is new again - Flettner Rotor Ship is launched
Discussion in 'Boat Design' started by rwatson, Sep 1, 2008.
  1. rwatson
    rwatson Senior Member
    Found a 16 foot catamaran version today
    Clarkey and hoytedow like this.
  2. rwatson
  3. DogCavalry
    Likes: 1,830, Points: 113
    DogCavalry Senior Member
    Problem with Flettner rotors is they have have super high lift, for the projected area, but als high drag. L/D ratio is not suitable for a cat, except as a research platform.
  4. rwatson
    I'm not sure where you get that idea from. Do you have any examples to show what you mean ?
  5. DogCavalry
    Marchaj, Aerohydrodynamics of Sailing
  6. rwatson
    Edited:
    Hmm. I downloaded the book No obvious comment on multihulls found.
    It does re-iterates many of the same formulae and documentation already posted in this thread.
  7. rwatson
    "Marchaj, Aerohydrodynamics of Sailing"
    Interesting excerpt
  8. DogCavalry
    Most excellent. I have it in hardcover, bought back in '90. He provides some excellent polar graphs as I recall. Extremely high lift, much higher than most rigs, but also highish drag. And with multi hulls, L/D ratio is paramount. I've always thought rotors would be fantastic on a heavy round chinese junk, or similar hull. It's not like a boat like that is going to be sailing so fast that apparent wind is a problem. Brute power is what you want for those guys.
  9. DogCavalry
    Read his brilliant stuff on multihulls elsewhere in the book. It's about the worst edited book I've ever feverishly read and reread. Just dismall structure and organization. But fantastic all the same.
  10. zstine
    Likes: 18, Points: 18, Legacy Rep: 10
    zstine Senior Member
    Agreed: In the research paper below, spin ratio, aspect ratio and end disk size were varied and evaluated for L/D using a CFD model. The MAX L/D was 5.5 with SR=2, AR=8, de/d=3. A modern sloop rig typically has a L/D of 8 to 10 and wing masts can get L/D up in the 20's. So, a Flettner rotor is not appropriate for any high performance, speed wise, vessel, assuming you want to go upwind.. you'd tack through 140 degrees! haha However, they may perform well at angles below a beam reach.
    https://downloads.hindawi.com/journals/ijrm/2016/3458750.pdf
  11. zstine
    I wonder if anyone has researched elliptical Flettner rotors? The end plate blocks tip vortex, but adds drag. Generally elliptical wings are the most efficient plan form as it reduces tip loss. Wondering if that carries over to Flettner rotors, especially in submerged applications like quantum stabilizers?
  12. rwatson
    I looked up the Morriseu paper,
    The Polars that he quotes ( D. R. Pearson, “The use of flettner rotors in efficient ship design,” are based purely on computer modelling) , and don't agree with actual experimental data from Thom OR NACA Technical Note 209, "Tests on rotating cylinders" by Elliott G Reid, Langley Memorial Aeronautical Laboratory. which is the basis for Jeremy Harris Excel workbook.
    This Data was purely derived from computer modelling.
    "The FR model was developed to be used in conjunction with Ptool, BMT’s proprietary marine power and propulsion tool [7]. "
    Which show a suspiciously Low Upwind ability.
    Actual real-world Reports on Rotors Upwind performance are invariably very positive.
    I have also been perusing Jospeh Norwoods publication, and his comments on high performance multihulls.
    In the biggest configuration postulated, he calculates up to 40 knots performance. This is not low performance.
  13. rwatson
    I am attaching another page from Joseph Norwood's publication, 21st Century Multihulls, for future reference
    Its significance is in 2 parts
    1) A formulae for calculating the power required to rotate Flettner Rotors
    2) A comment on an error that Thom made in his power calculations.
    These should be of real use to anyone contemplating further experimentation.
  14. rwatson
    A good introductory video
  15. Dolfiman
    Likes: 712, Points: 113
    Dolfiman Senior Member
    You can also remind here that we already discussed the coherence of the Norwood approach in a previous thread where I finally proposed a rewriting formula with coefficients that can be directly used and compared with test results if any (attached documents of the quote # 35) :
    Flettner Rotors - Calculating Rotating Skin Friction | Page 3 | Boat Design Net
