Everything Old is new again - Flettner Rotor Ship is launched
Discussion in 'Boat Design' started by rwatson, Sep 1, 2008.
  1. tspeer
    Likes: 293, Points: 83, Legacy Rep: 1673
    tspeer Senior Member
    At first I was confused by Figure 13 because it appeared that the rotor was producing thrust directly into the wind. But Figure 10 indicated the drag coefficient was always greater than approximately 1. Then I noticed that the origin of the polar plot was not zero thrust, but -150 kN! This is highly misleading.
    I question his conclusion, "Regarding the capability of FR to act as a propulsion device, it is confirmed that, in terms of magnitude, CL, and aerodynamic efficiency of FR is much higher than the values given by a wing of comparable aspect ratio." It's true that the lift coefficient is much higher than for a wing, but that really means the rotor is a more compact means of producing lift since the wing chord can be increased to produce the same lift with the same span. The efficiency, however, is not higher than what can be obtained with a wing. Figure 10 shows a maximum lift/drag ratio of 5.6 for the aspect ratio=8 rotor with large end plate - the best case. An L/D of 5 - 6 is on the order of what one would expect for the total aerodynamic lift/drag ratio of an entire sailboat, including the windage of the hulls, crew, rigging, nets, etc. The lift/drag ratio of the wing alone is several times better.
    And that doesn't include the power that is supplied to spin the rotor. If the power required to turn the rotor were applied to normal screw propulsion in addition to thrust from the wingsail, the wingsail is far more efficient than the Flettner rotor. The wingsail also wins out if the power is applied to boundary layer control instead of direct propulsion.
    I believe the case for the Flettner rotor is not aerodynamic, but in the area of handling and integration with the rest of the ship. The diameter of a Flettner rotor is smaller than the chord of a wingsail that can produce the same lift. This means it can fit between cargo holds without interfering with loading and unloading of the ship. The lift from a Flettner rotor can be easily regulated by varying the rotation rate. This makes it straightforward to effectively feather the rotor in high winds. However, the high drag of the rotor cannot be reduced, and a feathered wingsail has a fraction of the drag of a stopped rotor. So the heeling moment from the rotor in a beam wind can put a limit on the size of the rotor.
    Manfred.pech and CocoonCruisers like this.
  2. Squidly-Diddly
    Likes: 139, Points: 63, Legacy Rep: 304
    Squidly-Diddly Senior Member
    someone needs to come up with good spiral etc effect.
  3. rwatson
    Likes: 311, Points: 83, Legacy Rep: 1749
    rwatson Senior Member
    You are going to have to show the Math for that assumption.
    Yeah, but what fraction ?
    In 1930's, Rotors had less drag than sailing sailing ships with bare masts and rigging.
    I found a spreadsheet to calculate static loads on rotors, that I will upload for future reference.
    It has a section I am working on to calculate Drag on Airfoils. It shows about half a tonne of drag in gale force winds for a 7 metre x 3 metre Rotor, not huge.
    Also, Wing Sails have to constantly feather into adverse winds, putting lots of strain on the structure, and the ship too if the supporting column has stays..
    It's no wonder they havent been used for commercial installations.
    And the BIG benefit of Rotors is that they dont require constant attitude adjustment for optimum power, being omni-directional. In fact, at their optimum ~ 100 degrees wind angle, there is very little heeling moment.
  4. 1J1
    Likes: 15, Points: 18, Legacy Rep: 10
    1J1 Senior Member
    They are returning recently:
    DSIC and China Merchants test landmark sail propulsion system on VLCC - https://splash247.com/dsic-and-china-merchants-test-landmark-sail-propulsion-system-on-vlcc/ - retractable wing sails.
    Econowind solution - 2 retractable wing sails stored in a container.
    Econowind | Econology by wind https://www.econowind.nl/
    rwatson likes this.
  5. rwatson
    "2 retractable wing sails stored in a container."
    Seems a pointless exercise. Can you imagine two A class catamarans towing that thing.
    That's all they are equivalent to.
  6. Dolfiman
    Likes: 593, Points: 113
    Dolfiman Senior Member
    Another project, "Zéphyr et Borée" , a cargo ship with wing sails and LNG based propulsion, by students with the support of VPLP which try to develop a wing sail for various type of maxi ships. If interested, you can vote for them before June 3 (you have first to register to "The Aviva Factory", a Foundation of Aviva Insurance Company) , and if they are part of the 40 selected projects , they will receive a price :
    "Zéphyr et Borée" : #LaFabriqueAviva : découvrez Zéphyr et Borée qui participe à @LaFabriqueAviva #RSE #Concours #Votes https://lafabriqueaviva.fr/fr/project/2831/show#
    The Aviva Factory : La Fabrique Aviva - Donnez vie à vos Projets entrepreneuriaux https://lafabriqueaviva.fr/fr/
    VPLP wing yacht concept : Projects - VPLP Design https://vplp.fr/realisation/evidence/58.html
    Dolfiman, 2 minutes ago Edit Delete Report
  7. 1J1
    1J1 Senior Member
    Hello again! Have a nice read of this article about trials of the FEHN POLLUX which was retrofitted with the EcoFlettner rotor.
    Dolfiman likes this.
  8. 1J1
    1J1 Senior Member
  9. Dolfiman
  10. Burkhard
    Likes: 10, Points: 3
    Burkhard Junior Member
    By chance I came across this great thread. Now I am fascinated by a Flettner rotor.
    Burkhard
  11. Yobarnacle
    Likes: 130, Points: 63, Legacy Rep: 851
    They continue to fascinate me too. Magnus effect is fascinating. Some of the HPA compressed air rifles use a hop up device, that put a , well in shooting pool, it's called reverse English on the ball ammo. Makes it gain altitude when it leaves the muzzle because of Magnus effect, that the Flettner rotor works with.
  12. Burkhard
    Here a nice Video with a small Flettner rotor.
  13. Burkhard
    hallo yobarnacle, was ist mit deinem fr-projekt passiert? Sie wollten Ihren albin25 mit einem Rotor ausstatten.
  14. Burkhard
    hello yobarnacle, what happened to your fr-project? You wanted to equip your albin25 with a rotor.
  15. Yobarnacle
    My wife had cancer and our funds went to her cure. Since I'm retired regaining funds is very slow, so the project is temporarily shelved, but not forgotten or abandoned.
