Hi all,
I have been given the following formula to derive an estimate of the AVS for a given boat:
AVS=110+400/(SSV-10)
where SSV= Beam**2/(Ballast Ratio x Draft of Canoe Body x (Total Weight/1025)**1/3)
clearly for any given boat the AVS can be increased by decreasing SSV which in turn can be decreased by increasing the total weight by increasing the ballast. However the formula does not take into account where one would place the additional ballast. One could place it under the floor boards , could make the keel deeper or could place it on top of the mast, the estimated AVS would always increase and would be the same for all cases.
Does anyone have a formula for the AVS which takes into account the weight distribution/location ?
Thank you.
Thank you.
