My boat was purchased from a deceased estate and the tacho has never worked for me. It is a diesel motor and has a 1970/80's 4.0 inch VDO with no labels on it and has 4 terminals (12V, Sense and 2 x earths).
I did the normal thing and connected to the 'w' on the alternator. The tacho does not read under normal running but I noticed when a serious load is applied (ie the autopilot motor operates) then the tacho will read while the load exists.
There is an earth shunt installed with my xantrex battery monitor. The bolt holes where a magnetic pickup would be installed on the ford lehman still have original paint in them so have I assumed the tacho was never connected like that.
Anyone with thoughts as to why the tacho might behave this way.
