Epoxy vs Vinyl vs Polly
Discussion in 'Materials' started by RichardM, Dec 7, 2005.
  1. RichardM
    RichardM New Member
    I am boat shopping and I'm fairly new to boating and I'm confused by the different types of resins and methods being employed. Everyone seems to agree vacuum bag wet-out and epoxy resin apears to be the superior method of hull construction. Lighter, stronger, more stiff, better bonding, lower water transmitence and overall most cost effective.
    If it were simply a matter of economics, i.e. epoxy cost more than vinyl and vilyl more than polly I could understand why manufacturers choose different methods, but I am finding sport fish boats fabricated with epoxy construction competitively priced to their polly and vinyl counterparts.
    Am I missing something? Why don't all builders use epoxy?
    Polyester resin costs about 1/4 of epoxy. It is also easier to use. It wets faster and the mix ratio is not as critical. For medium performance applications, where minimum weight is not necessary, epoxy is a waste. On the other hand, the cost of the hull is maybe 10% of the total boat. That means that using epoxy increases the total cost by 15-20%.
  3. Deering
    Likes: 23, Points: 18, Legacy Rep: 44
    Deering Senior Member
    Epoxy is clearly superior in most respects. If I could buy the same boat, for the same price, in either epoxy or polyester, epoxy wins hands down, regardless of the usage. Different boats, different prices... now you need to consider other factors as well.
    Did that help? No? Sorry... welcome to boating.
  4. John ilett
    Likes: 1, Points: 0, Legacy Rep: 23
    John ilett Senior Member
    Poly or Viynelester boats can all use gelcoats to get the nice durable and glossy moulded finish whereas epoxy gelcoats do not really exist. For a moulded epoxy hull a poly gel can be applied with extra tie coats or needs to be painted which is not so durable.
  5. RichardM
    RichardM New Member
    Thanks John. I thought urethanes were taking the place of gelcoats o0n epoxy hulls.
  6. Raggi_Thor
    I think polyurethan paints can last as long as polyester gelcoat and look better without any waxing.
  7. John ilett
    Gelcoats may need polishing in the longer term but are harder, thicker and more durable (abrasion durability) than paints. Your paints are generally thin and when scratched will cut through to your undercoat or primer to often show another colour. Sure paints look good when new but but may look pretty average 5 years down the track. I feel when restoring older boats the gelcoat finish should be kept and maintained as long as possible.
  8. JR-Shine
    Likes: 4, Points: 18, Legacy Rep: 54
    JR-Shine SHINE
    I second this opinion - Gel coats may be harder, but they are also much more brittle - they crack. paint will not crack as easy.
    Unless you need it to build something in a mold - I cant think of any other application where I would prefer it over paint.
  9. John ilett
    The gel only cracks where a laminate is too flexible, usually solid laminate boats without sandwich construction.
  10. JR-Shine
    JR-Shine SHINE
    Please explain cracks in gelcoat around mounted hardware (hinges, bowrails, consoles, etc....)
  11. John ilett
    These are points where the laminate is flexed I imagine.
  12. JR-Shine
    JR-Shine SHINE
    I disagree, the gelcoat can crack due to its being brittle alone - the laminate under it does not need to move.
    You are right also, it the laminate moves - then the gelcoat will most likely crack.
  13. yokebutt
    yokebutt Boatbuilder
    But, but, but, John, how can that be, all the old salts I've talked to insist that solid laminates are much stronger....
    Yoke.
  14. John ilett
    A solid laminate boat is more robust and fail safe like, but that does not stop them flexing. The laminate will flex (not fail) and the gel coat being brittle cracks.
    Sandwich boats are typically much thicker/stiffer and do not flex.
  15. FAST FRED
    FAST FRED Senior Member
    "all the old salts I've talked to insist that solid laminates are much stronger..."
    What has fooled the "old salts" is that at high load spots the solid laminate is usually stiffer than cored material with poor (quick) construction for the high load.
    Cracks in gelcoat at stress points is a SURE sign of broken laminate and the need for a robust repair..
    Most glass is strong enough , but getting it stiff enough to not come unglued over the years is always the hard design part.
    Basically if its stiff enough to never flex , it may weigh a bit more , but will last almost forever.
    The old glass boats , that were built to what would be insane scantlings today , dont flex and will live till sunk, or burned.
    FAST FRED
