"epoxy vacuum basis"
Discussion in 'Fiberglass and Composite Boat Building' started by Tevens, Feb 3, 2009.
  1. Tevens
    Likes: 1, Points: 0, Legacy Rep: 35
    Tevens Junior Member
    the Baltic 43 old model constructed of kevlar and E-glass hybrid. says it is vacuum epoxy basis what does this mean? does any one know the Baltic 43's production system?
  2. robherc
    Likes: 5, Points: 0, Legacy Rep: 102
    robherc Designer/Hobbyist
    I'd guess either Vacuum-Bagged, or Vacuum-Infused. Either one CAN be used in most places the other would, but the Vac-Infusion will give a lighter part so I'd go that way if it's an option for you (steep learning curve, and high risk of ruining the part if anything goes wrong).
  3. limeyus
    Likes: 1, Points: 0, Legacy Rep: 25
    limeyus Junior Member
    If it's an older boat then it would be female molded with epoxy resin and the core vacuum bagged in.
    Also not sure why everyone thinks that an infused hull is always lighter.....it's not, expecially if each skin is bagged seperatly and the core installation is well done
  4. robherc
    Well, ok, then: VIP is my preference as it gives more time to get everything set up "just right" first, without having to worry about the resin kicking while you're trying to get everything set up.
  5. wet feet
    Likes: 106, Points: 43, Legacy Rep: 124
    wet feet Senior Member
    I would suspect that the answer lies in the third post and that the translator of the original document lacked the background knowledge to make clear the precise nature of the construction.Would an e-mail direct to Baltic elicit the truth?
  6. Tevens
    baltic didn't help very much. any more information would be helpful
  7. apex1
    apex1 Guest
    ask the germans
    Call or mail them:
    http://www.balticyachts.de/default.php?artid=kontakt
    they´ll give you the number of the license plate of the lorry that delivered the resin.:D
    Read: they are a bit more helpful than the factory!
    For general info about the technique:
    http://download.r-g.de/handbuch/handbuch_komplett.pdf
    written in German and English, goes very deep through the subject matter (for amateur boatbuilding a must).
    Regards
    Richard
  8. gamecock413
    gamecock413 Junior Member
    technicaly vacuum bagged should get 55-65% fiber, infuse 60-70% if your good enough to get it to 70%, then pre-preg shoud be at 70%. So, that says to me all things being equal in set up the infusion would be lighter than the vac bag. Also speaking from experience and burn out tests.
  1. Gasdok
  2. rwatson
  3. Cedric Oberman
  4. Mark C. Schreiter
  5. tbelliot
  6. DogCavalry
  7. Heynow999
  8. DogCavalry
  9. ahender
  10. mudflap
