Epoxy question
Discussion in 'Fiberglass and Composite Boat Building' started by Lister, Feb 13, 2012.
  1. Lister
    Lister Previous Member
    Is a chemical paint remover will remove the epoxy?
    The epoxy is on top of plywood.
    Thank you
    Lister
  2. Stumble
    Stumble Senior Member
    Probably not. You might be able to use a chisel to remove globs on plywood, but I don't know of anything that will remove it other than sandpaper, a chisel, a heat gun can accelerate the process... But the things that make epoxy suck a great structural material also make it a PITA to remove.
  3. Lister
    Thank you stumble. I appreciate.
    Now I know that I have to sweat to take apart that epoxy.
    Lister
  4. CatBuilder
    CatBuilder Previous Member
    A belt sander or grinder may work too, if you are steady with them. 36 or 24 grit.
  5. Lister
    I have a belt sander, and I am a strong person. I will try.
  6. michael pierzga
    michael pierzga Senior Member
    Dont burn up your boat...but...epoxy has a low melting temp . Give a hot gun and a sharp scraper a go. Soften the epoxy then scrap off ,then sand.
  7. lewisboats
    Likes: 128, Points: 0, Legacy Rep: 1603
    lewisboats Obsessed Member
    Agreed... remove most of the epoxy with heat and a scraper. Sanding will be much easier afterwards. Make sure you wear a good respirator, have decent ventilation and wear long sleeves, long pants and some gloves...that dust gets everywhere.
  1. Mark C. Schreiter
  2. mudflap
  3. Midday Gun
  4. schlever
  5. massandspace
  6. Cedric Oberman
  7. tbelliot
  8. DogCavalry
  9. Heynow999
  10. DogCavalry
