Note: This feature may not be available in some browsers.
I found this. It has an example of how I was imaging. The foam filled example seems closest to the idea.
It would be neat if rxcomposite could step through this example with his foam cored example.
Neat that the throw away former foam may actually help performance.
Cool! I guess unsurprisingly there is quite a bit of research on these topics. For trusses you can also find some interesting papers. The last one concludes that such sandwich trusses are comparable to honeycombs. It's not surprising that these can be very stiff and lightweight, but more importantly for boat building they can also have high specific compressive strength.
something wrong with the web. I quoted Dejay and answered but turned out as above. No amount of editing corrected it.
Waffle or pyramidal type core have been around at the same time as honeycomb. They just did not become popular. Waffle type may offer some increase in shear properties but loses some in vertical load bearing like the honeycomb. If you analyze the load bearing micro structure, the elements in pyramids are slanted while the honeycomb is vertical. In order to be "efficient" it must have vertical and diagonal members like a bridge structure. Note that the honeycomb is in the lower group of cores when it comes to shear properties. Cores are shear driven and in computing cored laminate properties, only the shear is computed in the calculations for the web part. The glue line/bondline or the web to flange region is sometimes considered but only if the design is so short that it becomes critical. The shear is greatest at the neutral axis and vanishes to almost next to nothing at the glue line.
So if I understand you correctly the cores are shear driven for boat applications, then waffle or pyramidial type core would actually be better?
Thank you very much RXComposite! This is very helpful.
I've looked a bit around and finally found some values for sheer strength of Styrofoam XPS foam. Ok it was right here on the forumIt seems if you get to densities of 40-45kg/m³ you get shear strength of 0.4 to 0.5 MPa. So comparable to lower density PET or PMI foam.
XPS Styrofoam RTM-X
Density 40 kg/m³, Sheer strength 0.4 MPa
XPS Styrofoam HD 300F-X
Density 45 kg/m³, Sheer strength 0.5 MPa
I've attached my spreadsheet with some collected material properties for foams, no guarantees that I typed off the values correctly though.
All of the 'solutions' people propose modify the shear and compressive (sometimes) properties of foams designed for alternative uses than marine foams. Or they modify the foam enough that it only becomes a former for a web of intricate fitments.
This is largely an exercise in reverse engineering a product whose primary goal was insulation into a 'cheaper' alternative to costlier marine foams designed at the outset with better properties. No, ta da, right?
Well, there is...none of the aforementioned 'solutions' accounts for the costs of said. And there is the ta da.
By the time you invest large sums of capital into machines and plants to modify the cheap core and add the labor of people running the stuff through a stitching machine; the stuff is no longer a cheap alternative, but a fantasy. And. And. Still not as good.
Now, there is some good in all the banter. Some of us gain a deeper understanding. But it is important to not keep attempting to solve the problem; that is dysfunction.
Those are my thoughts and comments. And I have used foamular 150 for amas. But its purpose is largely as a former and flotation. It is not designed for much hull stress. There are no G forces!
