Epoxy/glass schedule question
bobbrown
Junior Member
Joined
Jul 7, 2021
Posts
31
Reaction score
2
Location
SE Georgia
2 layers tape on seams. Will be unable to put fiberglass on hull within reasonable time.
So, the question centers on preparing the epoxied seam tape for the hull epoxy. The seam tape has no fill coat some weave is still present. Confused if I need to do any sanding before the hull glass since sanding would sand the top tape weave which I think is not advisable.
Will the exposed tape weave be enough tooth for the hull glass.
Thanks
Welcome to the forum.
What are you working on?
All depends on cure time vs delay time.
A few days delay will still develop primary bond.
Odd much of my original response disappeared.
Now you get the short answer
-Peal-ply-
Sanding with 40/60/80 grit is advisable if there is even an overnite delay. The grit depends on the tapes. Yes, primary bond can still be achieved on some resins for 72 hours no sanding, but I have sanded these bonds and didn't always like the layers sheeting off; so I started sanding all overnite cures long ago.
6 oz tapes 80 grit and just knock of sheen and avoid sanding thru
biaxial tapes no mat 60 grit, mat tapes 40 grit
I found that the tapes were just awfully rough to glass over once cured. A good bubble buster roller can manage roughness, but humps are really not easy to fair out..
Also, for thick tapes like 1208 or 1708; I precoat the steps they create before glassing over the top with thickened resin. More important on boat bottom where you want zero voids than say inside tapes..
Blueknarr mentions peelply. It is also a good solution and will help keep glass smoother for follow on layers and it will stop drips and runs from happening on mat backed tapes. I always regretted not using peelply on the inside of my boat because one seam was 3 tape layers and it ran pretty good. I applied 200 feet of tapes that day and didn't bother woth peelply and wish I had
Drips and runs should also be sanded out if they occur which is not good on real thin ply cores. Depends a bit on what you are building.
Thanks guys….14 foot flat bottom skiff for grass and mud flats in southern GA…go DAWGS!
Probably 6mm ply and 12 oz biax tapes. Those, I'd either peelply or sand with 60 grit. They have stitching that is higher than needed for follow on layers. The stitching is a good sanding gauge; don't go past removing the stitches.
Fallguy had a point that I was considering. Fairing in the tape seams before applying the hull glass. Wouldn’t take long and might save some work later on
I don't know how you plan to do the hull glass. I prefer to roll all but light wovens off a roll with lotsa sharpie marks to make sure length and overlaps land correctly. This allows you to prefair hot with thickened resin. Typically fumed silica because it knifes so well. A 4-6" flat trowel works nice; avoid excess; you can always be a little light, but the preloading is really wise on the bottom for perfect bonds.
Due to timing my basic plan is…2 offset seam tape…fair tape edges…then hull glass and faired…then paint. Any need for low density filler to fill tape weave. Thanks a lot for the advice
Attention Bobbrown; The Dawgs already went. Rather convincingly I might add. ................Now back to boats..........
Fairing is quite a task. For biax glass; sand all the stitching a bit and remove most of the sheen. You won't get it all. For a boat such as this, a gallon and a half kit of commercial fairing compound is the way I'd go.
