Epoxy gelcoat and non-skid negative
Discussion in 'Fiberglass and Composite Boat Building' started by idkfa, Nov 29, 2010.
  1. idkfa
    idkfa Senior Member
    War Whoop from an earlier post: Just use a Epoxy Gelcoat SP systems has a good one .and brush it in end of story. No pin holes ,Sandable You have a 3 hour wait and a 3 day lamination window ....
    And then paint with Awlgrip or similar... I think I'd like to go this way too.
    But, how do you treat/create the non-skid areas? with grit in paint? Is there any way to use a negative in the mould? Paint?
    tks
  2. Herman
    Herman Senior Member
    I do not know the history of your posting, but is this about using Gibco Flexmold anti skid profiles for plugs and moulds?
  3. idkfa
    idkfa Senior Member
    any non-skid profile. How do you create non-skid in a production build using epoxy laminates? epoxy gelcoat is not UV resistant like PE gelcoat and has to painted, then what about the non-skid? painted on too?
  4. idkfa
    idkfa Senior Member
  5. War Whoop
    Likes: 16, Points: 0, Legacy Rep: 84
    War Whoop Senior Member
    I have used the CR 3400 from SP in the past with great results.
  1. E350
  2. Crayolo
  3. sailswede
  4. Roly
  5. fritzdfk
  6. Capt Ram
  7. massandspace
  8. Cedric Oberman
  9. Mark C. Schreiter
  10. tbelliot
