epoxy curing time
Discussion in 'Materials' started by yipster, Apr 16, 2012.
  1. mydauphin
    Likes: 54, Points: 48, Legacy Rep: 575
    mydauphin Senior Member
    If the epoxy does not cure fully, unlike polyester, adding another coat over it won't fix it. Structurally it will stay soft and it may Peel or delaminate.
    A cool epoxy, that goes bad stays at chewing gum stage forever.
  2. PAR
    It's never good advice to cover a bad batch with another batch. You're just bonding to a bad batch which is self defeating.
    The only good advice in that situation, is to grind down the bad batch, until you're back into good portions of the laminate, then apply more goo.
  3. thudpucker
    thudpucker Senior Member
    Good advice PAR, but for me you're some 25 Years too late.
    Believe it or not, that Green F/glass coat made that boat look so good, that somebody stole it, trailer n' all.
  4. cthippo
    Likes: 52, Points: 28, Legacy Rep: 465
    cthippo Senior Member
    I use System 3 with the fast hardener and it reliably goes off down to 36 degrees f. Of course, now that it's 70 degrees in the shop instead of 40 i've had some rude surprises!
  5. pauloman
    pauloman Epoxy Vendor
    there are marine epoxies that will work and cure at freezing - I use and sell them every winter. That said, could be a mixing problem - off ratio etc, that sort of thing happens to everyone once they get past the beginner stage (it was never the new guys that fell from the rigging in the square rigger days, only the experienced guys)
    paul oman - progressive epoxy polymers
  6. Charly
    Likes: 32, Points: 0, Legacy Rep: 377
    Charly Senior Member
    Hey Paul, I made that very mistake this weekend, and on a part that would take a lot of effort to duplicate, to boot. I was mixing 24 oz batches-- two part resin to one hardner.I typically add 16 oz of resin first, and then the 8 oz of hardener. I don't know what I did this time, but now I have a sticky mess. So I have spent the last two hours with a scraper on it (it is 17 oz biax), with some vinegar, and it is very slow going. I am afraid a grinder would gum up real quick.
    Anyone have any speed up tricks? Hope the OP doesn't have the same problem.
    OH, and another question-- will vinegar, that is soaked in the wood compromise the bond (cedar strips) with a new batch of resin when it is cleaned up? Thanks
  7. tunnels
    tunnels Previous Member
    The best trick i know is do the job properly !! take more care !!be accurate with you measuring !!!. mix well and mix even more !!
    I really dont like working with epoxys at all .they are just a pain in the sit-upon !! stick smelly stuff !!
  8. Charly
    Thanks Tunnells!!!! Great Advice!!!! Also. Wear ya glasses!!!! When ya mix !!!:D:p
    ....and if I'd been weraing my glasses,. I would jave noticed that the OP is over a month old, so I guess (hope) his batch came out OK...:)
    ANyway, will the vinegar soak into the cedar and mess up a new bond?
  9. yipster
    Likes: 98, Points: 58, Legacy Rep: 1148
    yipster designer
    thx and luckely it did, i had a temp problem and it took a few weeks till the reaction picked up again with the temperature up but turned hard as rock
    dont know whats your problem but might try to give it some heat, wont hurt me thinks?
  10. PAR
    That's helpful, now that's is down.
    I'm not sure what epoxy experience you have (not much apparently), but it's not smelly and easier then polyester or vinylester, particularly for the novice laminator.
    I hope you managed to clean off the surface. Sometimes it helps to apply a talk or other powder to the sticky surface so the paper doesn't gum so quickly. Scrape the bulk off, then you know what's next.
  11. pauloman
    I am embarrassed to say that vinegar never seems to work for me - and I buy and test by the gallon - and I am in the epoxy business to boot! Guess my expectations for vinegar are just too high.
    No clue on the affect of vinegar on wood etc. I suspect it is so weak it doesn't do much and that the water in the vinegar is more of a problem.
  12. lewisboats
    lewisboats Obsessed Member
    Vinegar is a neutralizer...it doesn't clean worth a crap. It keeps the epoxy from curing while you clean it with something else. Mineral Spirits is about the mildest of the chemicals that actually clean it up. Lacquer Thinner works the best I find but it is pretty harsh. If you have a large gooey mess...Heat and scrape the worst of it off then, if you want to re-epoxy the base material don't use vinegar...go at it with the solvents then let it all evaporate for a good long while. It would be nice if you could heat the area to help with the evaporation but solvents tend to be quite flammable so unless you can pump heat into the area from somewhere else...you'll have to wait for evaporation to take its course.
  13. Charly
    Thanks guys, it is coming off with a scraper, though slowly. Tunnels really does have the best solution. Reminds me of an old Billy Joe Shaver lyric "the hardest thing I learned there is there aint no easy way"
