envirude 8hp 1994 choke!
Discussion in 'Outboards' started by scorpy, Aug 18, 2012.
  1. scorpy
    scorpy New Member
    hi to all,
    i have a 2strock outboard 1994 envirude 8.o engine,,
    it seems to run fine, but without pulling the choke, when i pull it the enjine cuts off.....
    is it something i need to worry about or i can keep running the engine Choke off?
    thank you!
  2. WestVanHan
    I'm not sure what you are saying.
    Choke is used for cold start only,once it starts-turn off the choke.
  3. scorpy
    scorpy New Member
    ok i guess i don't need the choke then, sorry for my ignorance,
    the engine has not been started in 3 years, i thought i needed to have the choke open in order to start it.
    thank you for your answer!
  4. PAR
    Typically the problems associated with a choke are the other way around, where you have to use it, just to keep the boat running (not good BTW). Yours seems to be functioning properly, as a choke applied to a warm engine will kill it pretty quickly.
  5. scorpy
    scorpy New Member
    thats exactly it.
