Your right about the Fn. I’m counting on the slim catamaran hulls to push past hull speed.
Of course you can always achieve 10 knots with lots of power. Just don't punish your propulsion equipment by burdening it with too much resistance.
You can lengthen the hull as others have suggested. 8 to 8.5 meter seems to be a sweet spot. Length is always beneficial. Try to design at cruising speed of 6 to 7 knots, 9 to 10 max. Your Length to Displacement ratio should be around 9 to 10.5 in order to be a high speed/ light displacement craft. Cannot be a displacement craft form.
At that Froude number, you need a high speed semi-displacement hull form. The midship coefficient you have suggest an elliptical hull or a deep V. Try a parabolic and higher midship coefficient. You Cb is also low at 0.408. Ideal would be in 0.48 to 0.52, typical of frigates and corvettes. If you look at modern AC hulls, you will see the same section except that the hulls are much slimmer because it is a cat. Low entrance angle also.
LCB of these hulls tend to be aft, around -2 to -2.25% so check your configuration. Bowrider might not work.
I am still at the early design analysis, I try to fit the ratios and coefficient around the design lane. In the final stage, I work around the same principle of Michlet. I create a "family" of hulls that fits the design goal, then choose. That way, I don't feed the program with random numbers that I just think of.
