Engineer/boat designer looking for a job
Discussion in 'Services & Employment' started by sushkin, Aug 27, 2011.
  1. sushkin
    Likes: 39, Points: 28, Legacy Rep: 20
    sushkin Junior Member
    Hello,
    I'm an engineer/boat designer and i am looking for a job in boatbuilding industry. I have finished National Shipbuilding University of Ukraine and have 3 years of working experience at the yard.
    Current skills:
    - 3d modeling in Rhino
    - hydrostatic, weight and stability calculations
    - strength and stiffness calculations
    - hullform design
    - scantlings design
    - composite laminate analysis
    - operating 3-axis CNC milling machine
    - photoreal render in 3Ds max and Vray
    also
    - Hand lay, laminating work and production of molds
    - precise mixing and use of resins, fibres and plastic materials
    - use of hand tools
    A little bit of my works:
  2. chrismcg
    Likes: 13, Points: 3, Legacy Rep: 36
    chrismcg Junior Member
    Hi,
    Just sent you a private message regarding potential work here in Ukraine.
    Chris
  3. sushkin
    still looking for a job:(
  4. Ibcharly
    Ibcharly New Member
  5. sushkin
    Hi!
    I can make 3d model of the hull on your picture (of course i will need some more dimensions and pictures) and make calculations in RhinoMarine for planning mode. Than you can 'play' with position and angle of the prop to reach desired trim and speed
  6. Ibcharly
    Ibcharly New Member
    http://www.correctcraftfan.com/reference/1997_brochure/index.asp?page=06
    This is appr. the dimensions of the boat, it might be a bit wider, maximum 2,40m and a bit longer, but maximum 18 feet! Center engine, and a hull with "pocket drive".
    I have a designer in DK to help me with the details and design, but not with the performance, and the hull below waterline!
    Perhaps you could email me directly, so we can discuss economy!
    henrik@kjeldskov.dk
    Best regards.
    IC
  7. Ismotorsport
    Likes: 7, Points: 0, Legacy Rep: 53
    Ismotorsport Junior Member
    Consulting work needed on design
    Send me an email if you would be interested in consulting on a design for a 52ft catamaran. Its in rhino and I need a NA to run it through hydro testingnand stability and figure out float lines based on layup schedule.
    Thanks
    Luke
  8. Ismotorsport
  9. yachtwerft
    yachtwerft New Member
    Looking for a job
    Dear Sushkin,
    we are a yard in the northern part of Germany, specialized
    in building custom build tenderboats.
    We are looking for a young, dedicated boat designer to complete our team.
    Assistance is needed with 3 D Construction and design for our individuel tenders in close cooperation with our in house production boatbuilding team.
    We are looking to hearing from you.
    Kind regards,
    yachtwerft meyer gmbh
    ppa. Michaela Meyer
  10. sushkin
    Hello, Ismotorsport and Michaela Meyer.
    I've answered you via email.
  11. Morgawr
    Morgawr Junior Member
    1. sushkin
    2. an2reir
    3. Engi R
    4. thefalcon
    5. VentureProducts
    6. Stephen
    7. Michael Y
    8. Liam Shea
    9. mksmarine
    10. Dharmik Raval
