Engine Troubles
Discussion in 'Outboards' started by teddybear664455, Jul 14, 2014.
  1. teddybear664455
    teddybear664455 Junior Member
    I have a 1973 glastron with a 60hp mercury tracker 2 stroke 3 cylinder engine. The motor will run at full throttle in reverse, but in foward gear will only run at half throttle. If i try to put the motor at full throttle, i will get a short burst of speed and then the motor will die until i bring it back down to half throttle. Any thoughts?
  2. Yobarnacle
    Likes: 130, Points: 63, Legacy Rep: 851
    Toss the Mercury in the trash. :D
  3. powerabout
    powerabout Senior Member
    if that was a 73 Merc and it lived in seawater I wouldnt waste my money.
    What are you looking at to determine that its full throttle in rev and not forward?
    Does it have a standard Merc control box?
  4. Yobarnacle
    Sounds like the notorious black box ignition problem that plagues 2 cycle mercurys.
  5. Mr Efficiency
    Get a workshop manual and follow troubleshooting procedure.
  6. teddybear664455
    Im new to the boating scene. I have no idea what a control box is.I weas basing my judgment off of the sound of the engine. The boat does not have rpm or mph guages that work.When i put the boat in reverse it speeds up super fast and gets pretty loud.When im in forward gear It doesnt get very loud and sounds different
  7. powerabout
    Post a photo of the lever you are pushing to make the engine
    go faster
  8. teddybear664455
    Ill have a picture up by the end of the day. I can tell you that from the number on the engine, it was made in 1995
  9. teddybear664455
    here are the pictures
  10. teddybear664455
    Ok powerabout, I made sure the fuel was new and good, I ran seafoam gas treatment through it, i ran seafoam carb and intake cleaner through it,I took out all three spark plugs and cleaned them, checked the spark plug wires and they look new, I checked the air filter it was good and clean, all three butterflies in the carb open and close at the same time and dont stick.After doing all this i put some muffs on it and ran it. I was able to throttle to the max in both directions without it bogging or dying. I guess the real test will be when i get the boat in the water saturday. Any other recommendations of things to check before taking the boat back out.
  11. powerabout
    Has your engine got a distributor or 3 coils
    Its hard for the untrained ear to tell if a cylinder is out on a 2 stroke.
    It could be running on 2 cyl
    Shorting the plug wires under load is the way to tell
  12. teddybear664455
    I believe it has coils. the wires go into a black box. I didnt take the box apart.When you say shorting out the wires under a load how do you go about doing that?When shorting the wires what will i be looking/listening for? If it is in fact running on 2 cylinders instead of three how do you usually go about fixing that problem? I got the boat and engine for free and its not worth spending a whole bunch of money on thats why im trying to do all this myself.
