I have a 75 Slickcraft 22' I inherited. Beautiful hull. Has a complete 225 OMC setup in it, only 597 hours on engine runs great. I'd like to switch over to Mercruiser. My understanding is if I can find a 302 Chevy mercruiser donor boat key to prop, I should be able to strip all OMC stuff off the engine, replace with mercruiser parts fix hole and be good to go? Are motor mounts the same and is the switch that easy?
Other option is a complete key to prop switch to a 351 ford mercruiser. Fix hole. Again are motor mounts the same or is stringer/motor mount glassing a issue?
