electronics for canting keel
Discussion in 'OnBoard Electronics & Controls' started by lausl, Apr 8, 2009.
  1. lausl
    lausl carpe diem yacht design
    we are designing a canting keel with 480kg ballast and are looking for hydraulics and electronics to move the thing - have you got experience - the system shoud have three buttons ,
    move the keel to starboard
    move the keel to port and
    move the keel to the middle position without using the pump
    (a sort of release valve) to save electric capacity, this only works
    when the keel is on the elevated windward side
    The movement should commence slowly, and also terminate slowly (ramp)
    Thankful for any input.
    Klaus
  2. TedZ
    TedZ Junior Member
    Are you looking for a turnkey job or recommendations on an approach?
    This is not difficult, could be tedious depending on equipment chosen. If you have two or more stage valves and a good way - and there are many - of knowing where the cylinders are positioned, any embedded system programer can program it and many single board processors the size of a pack of cigarettes will handle the work. I am a Rabbit fan. http://www.rabbit.com/
    Ted
  3. TedZ
    TedZ Junior Member
    As i think of this you could use two valves to get the ramp effect. Open one to start the motion and then when you want add a second one to increase the speed. Keeps the valve cost MUCH lower. Or one like this which is infinitely proportional. http://news.thomasnet.com/fullstory/31106
    This is the way you know where the cylinder is.
    http://www.encoder-technology.com/
    You should be on your way.
    Ted
