Electric Engine Certificates
Discussion in 'Powerboats' started by Leopard, May 21, 2022.
  1. Leopard
    Likes: 4, Points: 8
    Leopard Junior Member
    Hi,
    Could you please tell me which certificates do I need for my outboard and inboard electric engine for boat ?
    Do I need class certificates for my electric motor?
    If I build a BV class boat, is it okay if my motor has certificates from other classification society?
    Do I need certificate for my throttle and other things?
  2. Alan Cattelliot
    Likes: 220, Points: 43
    Alan Cattelliot Senior Member
    Hi,
    what is the lenght of the boat ? For which purpose should she be certified ? Should it be done under Belgium regulation ?
    In general, certificates are always mandatory in technical documentation. You should check directly the compatibility of the certificates at the office of the choosen legal entity.
    That established, we should be able to proceed with your last question. In general, the control system itself (commands, instruments, emergency, re-start after emergency, protection, isolation, cooling, batteries, motors, generators, converters, cables). In addition, you will have to check for some of them multiple standards or rule, as such installation should also be compatible with basics AC/DC requirements, for instance.
    Cheers,
    rwatson likes this.
