groper
Senior Member
- Joined
- Jun 18, 2011
- Posts
- 2,507
- Reaction score
- 175
- Location
- australia
And so it has begun...
These are the first 2 peices of this boat to be infused;
They are 2 of the webs in the forward beam which will also form the sides to the anchor locker etc...
All bulkheads and beams have been cut out of the airex foam sheets via CNC router from the CAD drawings, the files sent to the local CNC guy look like this;
Ive put together the mold for the hull "shoes" and this will be an interesting experiment to see how well a direct female mold for infusion works... its built very lightly out of 3mm foamed PVC as an inside former, with a skin coat of glass/epoxy to seal up the joins and staples etc... i have no idea how well its going to work with infusion, could be a complete disaster and destroy itself or a surprising success!
Here is an updated rendering of the boat as ive made a few changes prior to finally making up my mind
The weather is absolutely atrocious these last few days, so i cant do anything outside, but I will be gradually getting thru things over the next few months when the weather improves... just doing some more small infusions to get a better feel for how things work, then ill go for those hull shoes! So far so good... happy days
(note: thread discussing the design is located in the Design Forum at http://www.boatdesign.net/forums/boat-design/efficient-10m-displacement-powercat-44519.html)
