Well Joe, I’m afraid you just shot yourself in your foot. You have missed something essential regarding the ventilated propeller; the working area is a variable. On top of that you have not considered the impact of the torque coefficient Kq, which is essential for the estimation of the effective working area.
Working area is reflected in the measured thrust and torque from which the coefficients are derived by arithmetic.
The examples you refer to are, at best anecdotal; whenever I see a figure rounded off to double zeroes or to a fiver, I am sure that the number is at best a guesstimate. Your rpms are given as “8000 rpms”, speeds are given as 65 or 110 mph, there is nothing said about operating depth, propeller foil profile, blade profile, blade area ratio or the profile and depth of the steering fin in front of the propeller. The power figures are very uncertain, do you have dyno data to show?
The RPMs are around 8000. They are not around 7000 or 9000. That is accurate enough for a scaling relation. The speeds of SST45 are 65 mph on a short clorse, 110 mph for F1Sport on a short course. The factors that you mention are reflected in the thrust and torque vs. J. They will be different for different prop and gearcase designs, but that can't be fudged into existing data!The power figures are from the motor manufactureres' dynos. Actually, the SST45 motor develops less than 60 hp (54 shp) at 8000 RPM, it's peak hp range is 5500-6000 RPM but that is not were we race it.
Now, that said, let us check two of your examples, knowing that the basic info is vague. For the purists that may read this, I want to say that I am very well aware that I am stretching the extrapolations a bit beyond recommendations; it is for the good sake of demonstrating the principle. I have selected reference props from other sources than you used, in order to have a wider spectrum.
Wider spectrum? Not at this point. You recommended and I used the Genoa data, so let's stick to that until you send me links to your other sources.
First the SST45 case. Using your data we have the following:
P: 40,5 kW @ 8000 rpm (133,3 rps)
V: 65 mph (29 m/s)
D: 8,4” (0,213 m)
P: 10” (0,254 m)
Advance coefficient (lambda) 1,024 (=V/(D*n);
This gives the following:
P/D: 1,19 and the torque constant Kq = 0,0062. With this P/D value, we check available propeller data.
But the smallest torque coefficient in the Genoa data is .015! Let's stick to that data, you recommended it.
A/ First I looked into the figures given by Brandt (Modellversuche mit Schiffspropellern an der Wasseroberfläche; Schiff und Hafen no 5 and 6, 1973 The report is highly recommended!). Here a 3-bladed Newton Rader propeller (without cup) with P/D = 1,33 is tested. The BAR is ~0,7. This means that you may use the Kt and Kq values for this prop if you check its graph at lambda 1,33/1,19 x 1,024; ie 1,144 for rough estimates.
You can't use p/D=1.33 for the case where it's 1.2. The Genoa data include the case 1.2. End of my comments for now.
At depth of 50 % the N-R propeller shows Kq=0,018 and Kt=0,07. As has been shown, f.i. by Ferando et al, the ventilated propeller is operating with reasonably constant ratio Kt/Kq at varying submergences. Hence we may (for a rough estimate) use a linear relation between the observed Kq (0,0062) and the tank value (0,018). From this we get a correction factor of 0,344, which we use to find a new operating submersion.
The relative area at 50 % submergence is 50 % (surprise surprise…!), and the needed relative area is then 17,2 %. Now if you calculate the effective disc area as a function of operating depth, this will correspond to a submergence of 23,4 %. The SST propeller blades are thus operating at a maximum depth of 50 mm. The thrust coefficient is then 0,024, giving T= 880 N and a power of 40,5 kW.
B/ Next we check the Rolla propeller tested by Rose and Kruppa (Published FAST 91). This series is also based on the Newton-Rader propeller, but with a cup. Here we use the diagram no 15 (30 % submergence, atmospheric ventilation, shaft angle 4 degr). From the lambda 1,02 (right side) you go to the line showing lambda asf of Kt/J^2 for the P/D propeller. You will find a Kt/J^2 value of 0,04. From this value, you go vertically to find the eta value ~0,61, which allows us to calculate the “chart power” (=Trust*speed/eta) to 72,4 kW, and Kq = 0,011.
With the same correction procedure as before, we get a correction factor =0,559. This time it's applied to a 30% submerged prop (relative area is 25,24 %), we arrive at an operating relative area of 14,1 %, which we get with a 20,3 % submersion, or 43 mm in this case. The difference to the original N-R is explained by the cup and a higher BAR (=0.80) on the Rolla prop. The thrust coefficient is 0,023 and the resulting thrust 859 N.
C/ Now we check the 4-bladed supercavitating propeller type 841-B (origin KaMeWa if I remember ok), used by Niclas Olofsson in his thesis (Chalmers uni 1996, Gothenburg). Foil profile is a modified cambered wedge (“Tulin” style) and blade shape is more like the classic cleaver, with an area ratio of 0,58 and P/D is 1,24. Shaft angle is zero degrees. At 30 % submergence it has Kt = 0,035 and Kq = 0,0091. Efficiency is ~67 %. Repeat the correction procedure and you end up with trust = 868 N and submergence 23,3 % or 50 mm.
D/ Check with data from Szantyr (FAST 97). Supercavitating propeller (modified wedge), gives nearly identical results as “C” above.
Ergo: Four different ventilated propellers studied for the same task, thrust results 850-880 N and operating depth mean value 48 mm. Differences to a great extent explained by differences in blade profile and blade area ratio.
When I go through the same exercise for the F1 Sports, using the Rose/Kruppa data and a 3-bladed supercavitation propeller (H. Ghassemi and M. Ghiasi, Amirkabir tech uni, Tehran), I get thrust 2258 and 2332 N and a submergence of ~17,6 %; in this case 45 mm.
In all cases studied the nominal submergence is slightly less than you will see in reality, since the nominal value is “hiding” the ventilated wake after the steering fin. I would guess that the gearcases in the two examples will have diameters of, say 60 and 80 mm respectively, thus clearing the waterline with a slight margin.
From the examples above, I must say that the various tank data are surprisingly consistent, considering the lack of precision in the observations from your examples. There is a lot more to comment upon regarding the influence of design variables, but i think I made my point. In real life there is also the influence from dissolved air in the water. It normally varies over the day, with a maximum between 14 and 15 o’clock and a minimum in the early morning. In the afternoon, the water is thus supersaturated with air, that will come out of solution very easily and will then cause a loss of performance of propellers and hydrofoils.
I will be back later with comments on the shaft inclination subject. I certainly do not agree with your previous statements on the quality of test data here; you really must know how to use the tools available.
