Will Gilmore
Senior Member
- Joined
- Aug 29, 2017
- Messages
- 1,112
- Reaction score
- 534
- Location
- Littleton, nh
Two boats of equal displacement and length, but of different widths, will have different depths in the water. Per unit of immersion, the wider vessel will have greater load capacity. No calculations necessary.Halved power requirement compared to normal planing boat with the same total weight, load capacity and interior space.
I am not an NA. I'm an artist with some experience around boats and a tiny amount of boat design knowledge. I don't ask these questions to argue or even correct, but to encourage expanded thinking. I could be wrong and it's okay with me if I am. I just don't think I am.
If you are keeping the displacement the same and the length the same and the load capacity the same, the wider boat will be shallower in the water because the overall volume of displacement is equal between the two vessels. So, one variable has to change. It will be the draft. A shallower draft will plane more easily than a deeper draft.
A wider boat of equal length is simply a bigger boat in the water unless you reduce the freeboard and or cabin capacity vertically. This means the weight of both boats are close to each other and I would think, in terms of energy spent to get efficiently planing, less energy would be needed for the wider boat.
Again, I'm willing to be wrong. I just want to see where these ideas have been addressed.
I like your concepts, I love your goals, I hope you are very successful.
-Will
