rob denney
Senior Member
- Joined
- Feb 13, 2005
- Posts
- 992
- Reaction score
- 404
- Location
- Australia
The T60 is unique.
It is a foam/fibreglass boat built with no cutting or grinding of cured laminates and no wet laminating. Not quite clean enough to build it in your living room, but not far from it.
The process is explained at http://harryproa.com/?page_id=1327, including animations. It has as much in common with IKEA assembly as it does with conventional boat building, but with glue to hold it together instead of screws and bolts. Required skill levels are low and the finished job is of a higher structural standard than most production boats.
The T60 is 25'/7.5m long, has seats for 6 people, space for 12, weighs 200 kgs/440lbs, has a 40 gallon/150l fuel tank and is suitable for outboards from 15-70 hp. This one shown is the tender for a 60' harryproa. A wider version is being built as an all weather dive boat. Other sizes and boat types are in the pipeline.
