I'm designing my next sailing dinghy for racing, and after many experiments with various rigs on my previous projects, I want to go with the balanced lug rig again. One of the most important controls in balanced lug is the boom downhaul, which is the most stressed part of the entire rig.
The position of where the downhaul is attached to the boom makes a huge difference to the CE/CLR balance, sail twist and general sail shape shape. I find that adjusting it in various courses and air conditions can really help a lot with the performance, especially on the downwind.
The problem is, it isn't easy to transfer that downhaul to different positions on the boom while underway. On one of my boats, where I initially went with a loose-footed boom, I simply wrapped a line around the mast several times, leaving some slack in it, and attached the downhaul to it. When the downhaul is tight, the wrapped line cannot slide. When the downhaul is temporarily released, the line slackens, and can be pushed forward or backwards on the boom.
However, like I said, this only works if the foot of the sail is not lashed to the boom. Lashing brings a lot of other advantages, but makes it impossible for this solution to work. When I realized I have to lash this sail to the boom, I lost the ability to slide the downhaul.
So for my new boat, where I do want to have a lashed foot again, I am trying to come up with a way to have an adjustable downhaul position on the boom that does not interfere with the lashing. Ideally it would be controlled with a single or a pair of lines to slide that downhaul forward or backward as fast as possible.
The obvious solution is to attach the sail to the boom with a groove (like a track in the mast), and have boom downhaul also in a track on the opposite side of the boom. However this is kind of high-tech, difficult to make reliably (the forces on the downhaul in a balanced lug rig are truly enormous), prone to jamming due to friction, etc.
So I'm trying to come up with a low-tech solution to this issue. One idea I had is to run a line (blue in the following pic), tied to the boom at two points, stretched very taught, and have the downhaul (red) attached to this line via a pulley, so it can slide forward or backward, like a ski lift cabin on a cable.
There would be two additional lines running along the blue line, attached to the downhaul pulley to secure it's fore and aft position.
For this to work, the blue line must be as straight as possible. I'm sure you see the major issue here: due to the cosine angle, as the blue line gets straighter, the tensile force on it approaches infinity, breaking the line or buckling the boom. And if the line is relatively slack, then it will be difficult to adjust the downhaul position, due the the pulley having to travel uphill on that line. So this idea is a no-go, unless I use something like a 10mm Dyneema on a boom made from a solid steel pipe.
The only other thing I can think of is to have multiple fixed attachment points on the boom for that downhaul, and use a carabineer to transfer it from one point to another when needed. However, this is slow, difficult to do while underway, and probably impossible in heavy weather.
Are there any other low-tech solutions you can think of to have this downhaul position quickly adjustable when the sail is lashed to the boom as in the first pic?
