seasquirt
Senior Member
- Joined
- Dec 29, 2015
- Messages
- 384
- Reaction score
- 200
- Location
- South Australia
Check out your nautical supplier and see if there is a horn cleat with longer toes. Mine seem to have longer base flanges than your example, giving a bigger/longer load bearing area and less chance to pull out. They are cheap rough moldings from the land of instant landfill. I never believed epoxy would stick to it, even with surface treatment, but being buried in a couple of bands would make them immovable. I have no idea of expansion coefficient differences. Your cad pic example of a blister would pull out, or deform one side I think, but a complete band top and bottom would spread the loads and reinforce, and probably be easier to do. Your cleat pictured could have the nice tapered base filed to a reverse angle, or a tread pattern , to lock them in. Going through the middle gap would add little strength regarding the leverage and pull axial to the mast, but may add strength for sideways knocks.
This is my cleat, nearly 6" / 150mm across the horns. I've never had one break unless already badly damaged. The attachment method is the weak point. I use undersized screws so I can increase screw size later if I really have to. I also rasp/file the underside concave to fit the mast more snugly, to spread loads and give support.
