.dxf files??
Discussion in 'Props' started by Steamboat_Ed, Mar 4, 2019.
  1. Steamboat_Ed
    Steamboat_Ed New Member
    Hi gang; I'm wanting to print a half scale model of a controllable pitch propeller, 4 bladed, for a high speed steam engine I want to put in my boat. I'm not the best draftsman in the world but I do have rudimentary skills in CAD. I'm looking for .dxf format files of propeller blades that I can tweak for this application. Has anyone got links to share? Most everything I've found has been in .stl format which is just about impossible to work with.
  2. Yellowjacket
    Yellowjacket Senior Member
    dxf is a 2d file format. You can cut things out of plate, but it is just flat. The STL formats you see are real 3d parts that you could make a prop out of. The problem is that to print a 3d prop from metal, like aluminum would cost about a good bit. I was getting quotes on a 8 inch diameter 7 blade impeller for a waterjet and the cost was over $7000 to print it. We ended up printing a wax pattern and then investment casting it for much much less.
  3. Adler
    Likes: 17, Points: 18, Legacy Rep: 139
    Adler Senior Member
    What is the size of the hub ?
